Results 1 to 9 of 9
Thread: Clarifier use?
    Mar 2015
    Henderson, KY
    9
    Question Clarifier use?
    Does anyone use clarifier in their pool? What kind, brand,etc? Is it recommended?
    17k gal 16' x 32' IG concrete bottom FG sides 1985 , Hayward S244T sand filter , Hayward Super pump C48K2N143B1 1 HP 12 - 24 hrs , use bleach, K-2006C test kit.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Clarifier use?
    If you are following the TFPC methods taught here, you shouldn't need clarifier. That is what your filter is supposed to take care of, as long as all your chemical levels are where they are supposed to be for your pool.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Clarifier use?
    I agree with Charlie.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mar 2015
    Henderson, KY
    9
    Re: Clarifier use?
    That was a fast response. Thanks, was just wondering what else I may need to do. I do follow the bbb method.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Clarifier use?
    Clarifier is generally not needed, although a few people here do use it.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Clarifier use?
    I re read your post. You already use bleach. As long as you follow TFP methods bleach will keep you pool clear.
    Lisa
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Clarifier use?
    Clarifier is for pools that are not clear because they followed pool store recommendations.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    30,432
    Re: Clarifier use?
    What does your water look like?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Clarifier use?
    Welcome to TFP! This is how we maintain pools.
    Here are some of my fave Pool School articles in case you missed any of them.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
