Thread: Big hole in the liner
    May 2015
    Point pleasant, WV
    2
    I know we will have to replace the liner but I'm hoping we could make it through this summer. We just drained and filled it. We have a big hole in the corner right at the top, I'll try to figure out how to post a pic. My husband tried patching it and says the adhesive ate through the liner and the patch. He used one from the pool store. Any suggestions? I'm desperate and grateful for any ideas.
    23k gal, IG Vinyl, Hayward S200
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Re: Big hole in the liner
    Quote Originally Posted by Anotheremail View Post
    What type of adhesive. Google patching vinyl liner and the brand "Boxer" and use that. You can start with one patch then put a bigger one over that and then another if needed.
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    The adhesive should not have done that. Did they sell him a patch kit or separate items? Is your liner brittle and crumbly in the damaged area?
    Love TFP? Become a
    TFP Supporter!
    Orlando, FL
    690
    That doesn't sound right at all. How old is the liner? Did it dry out and become brittle before it was patched?
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    May 2015
    Point pleasant, WV
    2
    Honestly, he's not the brightest guy in the world. It could have been user error. I will attempt a patch myself tomorrow if you think it's possible. Should I have him put the strip of liner at the top back in?
    I have no idea on the liners age. We bought this place 3 years ago.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If that were mine I would go to the pool store and see if they would sell you a scrap bit of vinyl maybe 2x2 ft and some vinyl adhesive and cover that entire area with it. Often stores that also sell pools will have scraps / old color sample swatches that they will sell for this purpose. If not try ebay, you can often get up to 4x4 ft pieces under $10 or so.
