Results 1 to 13 of 13
Thread: New here, Need Advice
    ashleyoutz's Avatar
    May 2015
    Sanford, NC
    8
    Unhappy New here, Need Advice
    Need advice! I'm new here! My chlorine was very high for about a week. It has finally calmed down. But now my TA is 0. What should I do to raise the TA without messing anything up? Please help! Thanks in advance
    Here are my numbers~
    TC~ 5
    FC~ 5
    PH~ 7
    TA~0
    CYA~ 100
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: New here, Need Advice
    Welcome to TFP!
    First question I have is, what are you testing with? I've never seen a test result of zero for TA, so that has me a little suspect.
    Baking soda will increase TA but we need a high confidence level that what you are using to test is accurate before we can tell you how much to add.
    ashleyoutz's Avatar
    May 2015
    Sanford, NC
    8
    Ok I'm using AquaChek 7 Pool & Spa test strips.
    ashleyoutz's Avatar
    May 2015
    Sanford, NC
    8
    ashleyoutz's Avatar
    May 2015
    Sanford, NC
    8
    ashleyoutz's Avatar
    May 2015
    Sanford, NC
    8
    Also, I have an AG, Sand filter, 18' Round, 52" deep
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Welcome to TFP!
    We here at TFP have very little confidence in test strips. They are known to be wildly inaccurate, as bad if not worse than pool store testing. This is why we always recommend you purchase a high quality test kit, either the TF-100 or the Taylor K-2006. Accept no substitutes. In Pool School there is a section on these test kits. Strongly suggested that you read up on it. While we don't usually suggest that you use pool store testing, in this case it would do you good to have them test a sample while you are waiting for your test kit to arrive (hint that you should buy one!). This will give us a better idea of where your pool is at chemically.
    ashleyoutz's Avatar
    May 2015
    Sanford, NC
    8
    I will def buy one!! Glad to know!! Thank you!
    AG, Sand Filter, 18' round, 52" deep, vinyl liner
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Thanks for your quick response and excellent pics.
    I kinda' suspected you were using the strips. They are simply not precise enough to follow our methods. For example, note the range on TA...it goes from 0 to 40. In reality, your TA could be anywhere in between that. Yes, it's still low in either case. But there's not enough precision there for us to tell you how much baking soda you need to add to get it to where it needs to be.
    I would suggest you get one of the Recommended Test Kits if you are serious about taking control of managing your pool.
    Also, to give you an overview of the TFP process, I would suggest reading these two articles: ABC's of Pool Water Chemistry and Recommended Pool Chemicals.
    ashleyoutz's Avatar
    May 2015
    Sanford, NC
    8
    Ok great!! Thanks so much for your help! I am def going to buy one of the recommended test kits and I'll get back to you on my new test results🏼
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Welcome to TFP!i am happy to hear you will be buying a recommended test kit!there is a direct link in my signature.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Best bang for your buck would be the TF-100, from TFtestkits.net. More of the supplies you will use most often than in the K-2006. Same items, just more of them for little more $$. Also that's the best place to buy refills for either kit.
    While you are waiting for your kit, please do read in pool school for what chemical levels work best for your pool.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP!
    Here are some of my fave Pool School articles in case you missed any of them.
    TFPC for Beginners
    Here are the Recommended Levels for your pool.
    Here is the Water Balance for a saltwater pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
