Thread: Spa jet options
    Feb 2014
    Texas
    42
    Spa jet options
    Hi forum community,
    I'm looking for spa jet options for my gunite spa. The original spa jets are powered by a spa blower and work great. However, I'm trying to determine if I can change the jet tips out with something with a stronger water jet.
    The attached picture is of a 1.5 inch spa jet. This is an ultra simple setup. Looking for any recommendations on spa jets they are compatible.
    Thanks!
    May 2015
    Chicago, IL
    508
    Re: Spa jet options
    Did you forget to load a image? I don't see one.
    Feb 2014
    Texas
    42
    Re: Spa jet options
    Images are there
    May 2015
    Chicago, IL
    508
    Re: Spa jet options
    Lol I see them now.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Spa jet options
    What you are showing is the external eyeball fitting. That is not the jet nozzle. The jet nozzle is deep inside the spa wall and you will need to remove the eyeball to see it and remove it. Sometimes you can change the size of the nozzle and if you are looking for a stronger jet, you will want to go to the next smaller size.
    Mark
