Thread: filling a new Intex pool
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Hi guys
    I have a question:
    Is there a 7 day plan for filling up a new Intex 24x12x 52' ?
    What would be your recommendation?
    Thanks
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: filling a new Intex pool
    Any help?
    strutaway's Avatar
    Jun 2013
    LA (Lower Arkansas)
    28
    Is there a reason you need to take seven days?
    18ft. Ultra Frame Pool. 1hp Advantage pump. 18 inch sand filter. Skimmer from previous Easy Set suspended over pool. Barracuda Ranger cleaner, new Hayward Leaf canister which is the best purchase I have made. Lots of dust here from gravel roads plus tree stuff.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Should be able to fill it in 1 or 2 days max.
    Do you have one of the Recommended Test Kits, I use the TF100 from tftestkits.net.
    Here are some of my fave Pool School
    Here are some of my fave Pool School articles in case you missed any of them.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here is the Water Balance for a saltwater pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
