Thread: Newbie here Chlorine Tabs and floater
    May 2015
    Cherry Hill NJ
    11
    Should we be using a floater ever? Or is bleach good enough.
    27 ft above ground with sand filter.
    Hayward Power Flo LX
    17,000
    TF-100
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Newbie here Chlorine Tabs and floater
    Welcome to TFP.
    Plain, unscented liquid bleach without any added thickeners is recommended for long-term chlorine maintenance. It's OK to use a floater with tabs temporarily if you will be out of town and the pool will be unattended. Just be aware of what your CYA level is as the tabs will increase that.
    May 2015
    Cherry Hill NJ
    11
    Thanks. I always hated the tablets and the floater.
    17,000
    TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Welcome to TFP!
    Get one of the Recommended Test Kits, I use the TF100 from tftestkits.net.
    Here are some of my fave Pool School articles in case you missed any of them.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here is the Water Balance for a saltwater pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
