Results 1 to 14 of 14
Thread: Broken Fixture
    Jun 2014
    Danvers, MA
    27
    Broken Fixture
    Hello,
    I went to open my above ground pool and the fixture that attaches the hose to the filter is snapped. My ex closed the pool last year for me and I don't remember him mentioning this to me but he might have!
    The part that snapped is attached to the housing for my filter and I'm not sure how to get it off?
    11164841_10152746264251567_4424022403823660365_n.jpg11295701_10152746266026567_174262195377244851_n.jpg
    Kris Ann, Massachusetts
    30' x 15'; AG; Cartridge; HP 2.0; Installed 2012
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    Re: Broken Fixture
    I am no expert in plumbing but it looks to me like the part with the handle has a union that can be unscrewed.
    The part that is still in the tank---------There is some sticking out on the top. What about on the bottom?
    I will show this to my husband and get his input.
    Hugs! We will find a way to get your pool going.
    Kim
    Jun 2014
    Danvers, MA
    27
    Re: Broken Fixture
    Yes there is nothing on the bottom. Not sure how I could grab onto it to twist it out. Maybe smash it?
    Jul 2012
    Tallahassee, FL
    30,672
    Re: Broken Fixture
    NO Smashing allowed!
    I am thinking-----------do you have a rubber mallet (hammer with a big piece of rubber instead of metal)? Tap GENTLY counter clockwise (lefty loosey). See if you can get it to move that way.
    I am hoping there are threads inside with teflon tape on them to stop it from leaking. If so it should twist out.
    That is plan A. I am thinking on plan B.
    Kim
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Broken Fixture
    You might also be able to get a rubber strap wrench around it and twist it out
    Jun 2014
    Danvers, MA
    27
    Re: Broken Fixture
    There is some kind of putty in the threads.
    There is no lip on the bottom (my picture doesn't show) so I couldn't get anything around it.
    May 2015
    Carlisle, PA
    42
    Re: Broken Fixture
    That is definitely a serviceable ball valve (IE it comes apart where the big ring is on the side that broke off) so this can be fixed but getting the broken piece out of the filter is the first step. The putty in the threads is plumbers putty (a sealant) which should not be used on plastic fittings as it can degrade the plastic or expand and crack it. If that valve was closed through the winter it's likely that there was water trapped in that part and it froze and broke.
    Now, you MIGHT be able to GENTLY clamp the broken portion with a pair of channel lock or vise grip pliers and back it out that way. Put the pliers on perpendicular to the fitting as close to the threads as possible and try to turn it (see the marked up picture below, excuse my crude drawing of pliers). If it doesn't seem like it wants to turn with just the pliers you can try gently tapping the pliers with a hammer. Be extremely careful that you don't break the rest of the fitting off.
    21K gallon, AG Vinyl 30' Round, Hayward Perflex EC50C92S DE Filter (25 sqft), Hayward Power-Flo Matrix 1HP 50GPM Single Speed Pump, Taylor K-2006 FAS/DPD Test Kit
    "In God we trust, all others bring data."
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    Re: Broken Fixture
    Pliers might brake that piece. The strap grabs more surface. Try it
    Rubber strap wrench
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    Jul 2012
    Tallahassee, FL
    30,672
    Re: Broken Fixture
    Love the drawing. A picture says a 1000 words.
    Above all else go slow and easy.
    Let us know what you try and what happens.
    Kim
    May 2015
    Carlisle, PA
    42
    Re: Broken Fixture
    Quote Originally Posted by Pysiek View Post
    The strap wrench may have trouble getting a hold of the bottom part where it broke at an angle BUT Pysiek is correct. Try the strap wrench first.
    Pysiek's Avatar
    Apr 2012
    419
    Re: Broken Fixture
    Quote Originally Posted by mopar440_6 View Post
    Pretty sure it will. But always good to try. I just wonder what filter is that? Maybe there is a nut on the other side
    Jun 2014
    Danvers, MA
    27
    Re: Broken Fixture
    Thanks everyone! You're awesome. So I ran it over to the pool place today and they managed to get it out without breaking anything. And they only charged me $10! Phew.
    Now to open my extremely green pool for the first time by myself. The liner was torn, got that replaced. Got this fixed. There are literally ducks in my pool at this moment. They won't be happy to see me, they're getting comfortable.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: Broken Fixture
    10 bucks! What a ripoff! Evict the ducks and SLAM - Shock Level And Maintain your pool.
    Jul 2012
    Tallahassee, FL
    30,672
    Re: Broken Fixture
    QUACK! So have you found your best place to get bleach from? You are going to need lots of it to get rid of duck poo LOL
    Let us know if you have ANY questions! Some one will know the answer!
    Kim
