Thread: where to put the through wall skimner on intex pool?
    debrrose's Avatar
    Feb 2013
    Florida Space Coast
    7
    I have an 18' ultraframe with sand filter and separate chlorine generator. I got a Hayward Skimmer and have figured out the parts to adapt standard pvc pipe to those obnoxious non-standard intex hoses and fittings.... now for the part where I chop hole in the liner. What I'm wondering about is stress on the fabric of the liner, and uneven pressure on the support posts if the liner gets warped over time. So, looking at where the intake/outflow holes already are, it seems like I ought to go to the opposite side of the pool then over one section toward the original intake (so there will still be a circular pattern of water flow).
    I know people have added the hayward skimmers by cutting an additional hole - how has that worked out, and where did you place the hole?
    Also, where should the water level hit on the Skimmer?
    Working on a scheme to hard-plumb my 18' UltraFrame and add through-wall skimmer, vacuum port, fountain, pasive solar heater, and auto-fill water pipes. I know I can do it if I just get the valves right.... 😎
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: where to put the through wall skimner on intex pool?
    This thread my help you out. It has good pics.
    Adding a Hayward Thru-the-Wall Skimmer to Intex Metal Frame Pool (PICS!!
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
