Results 1 to 10 of 10
Thread: How do I link to photos on Dropbox/Carousel
    May 2012
    Toronto, ON
    463
    I store my photos to Dropbox/Carousel. I want to link to some of them on this forum but it doesn't seem to work.
    For example here is a link that I get when I click on Share at Dropbox. "https://www.dropbox.com/s/xh221gjv4i3mjl2/2015-05-09%2013.11.16.jpg?dl=0". When I try to post the photo here via a URL in img tags it doesn't work - either with or without the ?dl=0 at the end. Hence the two broken links below.
    But if I put that URL directly into my browser it works. (But perhaps this is due to authentication issues).
    Anyone have any suggestions? I like Carousel/Dropbox as it will automatically upload photos from my iPhone. I can't use the direct iCloud upload due to the security software on my corporate issued iPhone.
    Vinyl 18'x36' in-ground 100,000 L, Jandy Aquapure 1400 SWCG, Jandy Lite2 heater, StaRite System3 filter, Evac tube solar heating panels
    Jun 2014
    15,004
    Re: How do I link to photos on Dropbox/Carousel
    TEST: https://photos-4.dropbox.com/t/2/AAA...00&size_mode=2
    Well, I got it to show as a hyperlink, but I'm still stumped on getting it to show as an image via IMG. Ggrrrr.
    May 2015
    Chicago, IL
    508
    In the bar above where you type your text, there is a icon that looks like a picture. Click on that then choose, URL, and add the link in the dialog box.
    bbodb1's Avatar
    Jul 2013
    Central Arkansas
    103
    Edit:Ozzy47 is spot on but just in case that does NOT work for you, here is another method.
    I've never used either service, but I do use PhotoBucket and they make it easy. The format of the Image tag is as follows:
    -IMG=http://i840.photobucket.com/albums/zz326/sevenof400/The%20Lads/Many%20Mallerys.jpg-/IMG=
    EXCEPT that I have replaced a left brackets [ with a hyphen - and the right brackets ] with the equal sign = so you can see the IMG statement here.
    That same line (from above) when properly formatted produces this:
    If you can find the URL for the picture you want to use, simply replace the URL in the line above (that's the stuff including the http and continuing through jpg), change the brackets (as noted above) and you should be good to go.
    Does that help?
    20K gal, IG vinyl, Waterfall on 2nd pump (1HP US Motor), Dolphin cleaning system, Central Arkansas, installed 1999
    2 Haywood Super Pumps, 1HP (main and waterfall pumps), Purex Triton II (TR 60) Sand Filter (replaced original 2016)
    May 2012
    Toronto, ON
    463
    @ozzy - That is what I did but the URL is different from the one that Texas Splash linked to and what you used.
    @Texas Splash - how did you get that URL? That is not the same as what I got for some reason.
    And isn't using the Icon the same as enclosing the URL in IMG tags?
    May 2015
    Chicago, IL
    508
    If you hover over the image in dropbox, right click it, and choose Copy Image Location, paste that url in the image tags.
    May 2012
    Toronto, ON
    463
    Thanks Ozzy.
    May 2015
    Chicago, IL
    508
    Not a problem sir.
    Jun 2014
    15,004
    Wayner, I believe I got that URL by right-mouse clicking the pic and going to properties.
    Bbodb1 - That is a great pic of the pooches taking a plunge.
    dsilchenstedt's Avatar
    May 2015
    Rockport tx
    62
    test
    Sweet, thanks.
    Round Frame Pool 15' x 42" (app. 3800 gallons) converted to Krystal Clear 2800 GPH .75 HP (conversion thread Here all the links/info you will need are within), TF100 Test Kit with speed stirrer. My first SLAM
