Thread: help!
    May 2015
    Clarksville
    1
    help!
    OK so I gave a 30 foot above ground pool. I moved in to this house and the pool was never covered. I have never had a pool. I mistakingly added chlorine before fixing the ph. Now my ph is high and I added a half gallon of muriatic acid. Pool is cloudy and tinted green. Should I have vacuumed it first? How at this point do I lower ph? It isn't lowering. Thanks.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: help!
    Welcome to TFP!
    First, how are you testing your water?
    Your PH may be much higher than 8 and this is why it is not lowering.
    Can you post a full set of numbers if you have them?
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: help!
    Welcome to TFP!
    How much chlorine did you add? It could be skewing your pH test.
    I will kindly suggest just slowing down, and taking a little step at a time. If you can answer AZgirl's questions it will be a good place to start.
    Essential Links:
    rdw1961's Avatar
    May 2012
    Mount Pleasant, PA
    17
    Re: help!
    I suggest picking up a TF-100 test kit and following the advice of the knowledgeable folks on this site. You'll be splashing it up in your pool before you know it!
    24' Above Ground Round vinyl
    DE Filter pump 1HP
    Flow Rate 39GPM
    14700 gallon
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: help!
    Just to clarify here, the pH test can read falsely high at FC (chlorine) levels over 10ppm
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: help!
    Welcome to TFP!
    Get one of the Recommended Test Kits, I use the TF100 from tftestkits.net.
    When you get it give us some test results and get ready to SLAM Your Pool.
    Here are some of my fave Pool School articles in case you missed any of them.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
