Thread: Any Way to Free Up Pentair 2000 Backwash Valve?
    May 2015
    Moorpark, CA
    171
    I have a Pentair 2000 DE filter (thanks to the people on the forum who identified it for me). The backwash lever moves if I use my foot. I was wondering if there is a way to free it up, perhaps by cleaning it, or lubricating it, so it could be moved by hand.
    Here is a picture of valve handle.
    Can Anyone Identify This Filter
    Michael
    20,000 gallon in-ground gunite/plaster pool (1992), attached spa with spillway, Pentair Superflo 1.5 HP pump, Smith booster pump for pool sweep, Pentair 2000 DE filter, Sta Rite Max-E-Therm 400 heater, Silencer Blower 2 HP for spa, Polaris 280 pool sweep.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Any Way to Free Up Pentair 2000 Backwash Valve?
    Mine takes some serious tugging, too. I imagine there must be a way to disassemble it and lube it, but I've never cared enough to look. When you get done and the tank is full again, shut the pump off and move it back and forth a few times to dislodge any grit that might be caught in there. Sometimes I get a drip but opening and closing it a few times and letting the water gravity feed and wash it clean stops it.
