Results 1 to 8 of 8
Thread: Is my Hayward Pool Heater Supposed to be this Loud?
    Jun 2014
    Youngstown, OH
    182
    Bumping an old thread.. I got the H200 and just fired it up.. It is pretty loud.. Did you find this to be normal in your research then?
    Moderator note: This was moved from an old post
    Installed in 2014 - 24' Round x 54" Bliss XL Above Ground Pool 14,090 gallons // Hayward S270T Pro Series 27-Inch 350lb Sand Filter // Hayward SP15922S Power-Flo Matrix Above-Ground Pump 2-Speed //
    Installed in 2015 - Hayward H200FDN Natural Guess Heater // K-2006 Test Kit
    Youngstown, OH 44514
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    Re: Should a pool heater sound loud?
    The FD Hayward heaters are loud. They have a blower motor in them which can be a source of the loudness. If you are concerned, have a gas pool heater repair company come out and look at the unit. They should be able to also check the gas pressure. Gas pressure is measured in inches water column. Like 3.5" W.C.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Jun 2014
    Youngstown, OH
    182
    Just installed and fired it up.. Not sure if you can tell by the video, hopefully you can..
    Pool heater - YouTube
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    Re: Is my Hayward Pool Heater Supposed to be this Loud?
    I'm guessing that the only sound on the video is the heater?
    Paul
    Jul 2010
    IL
    201
    My H250 is VERY quite. You have to be pretty close to it to even hear it running. My H150 was MUCH louder and went bad after 4 yrs.
    24' AGP Sentinelle 54" , 1hp 2 speed power-flo matrix, New 250K to replace the 150k BTU heater, pool roover Jr. Aqua Trol SWG, Large deck, taylor k-2006, Majestic Stairs with colored LED, COLD BEER
    Dec 2009
    Central Massachusetts
    2,690
    Thats about what my 400,000 btu sounds like.
    Whats the water gurguling sound? Your pump?
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    Have the installer come back and measure the gas pressure and check things out. It's under warranty so don't try to resolve it yourself.
    Paul
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Having heard many of these heaters I find the sound ok. Ask the installer if he took gas readings when he installed. Always a good idea.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
