Thread: Green pool questions
    Our first year opening a pool on our own. We had it cleaned professionally and new water last year with our local pool company. This year we have tried everything to get it Clear with no results. It is a teal blue merky color. We have a 16x32 inground pool. Thank you!!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Green pool questions
    Welcome to TFP!
    Have you tested your water? If so what test kit are you using?
    Can you post a full set of results please?
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    Welcome. Sounds like you need to SLAM it as described in Pool School. You'll need a fas-dpd chlorine test to accomplish that. Please read up there on our recommended test kits.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP!
    Get one of the Recommended Test Kits, I use the TF100 from tftestkits.net.
    When you get it give us some test results and get ready to SLAM Your Pool.
    Here are some of my fave Pool School articles in case you missed any of them.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here is the Water Balance for a saltwater pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
