Thread: foozed-waterfall questions
    Mar 2007
    Raleigh, NC
    21
    Any advice on how to build a waterfall / rock water feature would be helpful here!
    I had my PB pre-plumb but all I have is a pipe sticking up through the concrete because I'm not comfortable enough taking it on yet...
    Pool Size: 35’ x 26’ x 15’ x 8’Perimeter ft. = 104 Surface area = 557sq. ft. -- Trapezoid shape w/tanning ledge and water feature--Depth ~ 3.5’ - 5’ - 4’deep
    Jandy 2.7 Horsepower VSE Stealth pump -- Jandy CV340 Cartridge Filter -- Aqua Pure Salt System
    Ft Lauderdale, Florida
    1,455
    Precast waterfalls are probably the easiest.
    Connect with Flex pipe so you have some mobility with the waterfall. The waterfall will sit over your coping and allow the flow into the pool.
    Prices are everywhere, depending on how large and what effect you want. Here is an example, (from goggling precast waterfalls)
    http://www.poolrock.com/
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Waterfall
    Foozed,
    The waterfall is about the only thing I have not rebuilt/upgraded. There is the single pipe coming up through the rocks. Poolcast sounds like the easiest solution. The waterfall is a really nice feature to have.
    Charlie
