Results 1 to 7 of 7
Thread: New Liner stretch concern
    Hello everyone,
    I just finish converting from an overlap liner to a beaded liner and when I started filling it I notice that it may be too tight.
    I know people are saying it can stretch but I'm worried.
    Here is the link for the pictures:
    https://plus.google.com/photos/11040...CNycmODrhPniYQ
    Thanks
    Phil
    13K gal, vinyl Atlantic 24' round,
    9th year & still crystal clear thanks to TFP!
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: New Liner stretch concern
    I can't tell, but when I had an ago, I remember that I needed to be in while filling it to smooth out the bottom toward the sides.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    I looked at it today and it is a lot more flexible then yesterday (lot warmer outside). Now my concern is the liner is tighter on one side of the pool. Should I drain the water and recenter it? There's not much water in it.
    Thanks
    Phil
    Apr 2015
    East Wenatchee WA
    39
    There are some really good liner install videos on YouTube. I've only ever done overlaps so I'm not much help. Good luck!
    15'x30' oval AGP. 12000 gal. 1 HP pentair pump. 19 inch sand filter.
    Auto vacuum thing that works through skimmer. Solar cover.
    OLD 400ish gallon Cal Spa hot tub with two new pumps (ouch)
    Well like they all said, on a hot day it will stretch no problem. It did not need to stretch that much but It was my first time installing a pool liner.
    Casey's Avatar
    SW PA
    10,427
    How's it look Philippe? Looks like you did a good job. Is it full?
    It's getting there, I'm filling the pool with water from a well, so it's not going very fast and also there's been quite a few days of cold temperature.
    But so far I find the water to be a too little clear, I'm worried about vacuuming all summer long...
