Thread: Leak - How hard to fix? Pics inside
    Jul 2011
    North East
    135
    Have a leak from the top of the pump. Pictures attached. Not sure how much of a pain this is going to be to fix. The top of the pump is a threaded connection; however the valve is a slip connection. Will the tan piece just unscrew to release itself from the valve and let me remove/readjust the leaky piece?
    25,000 gallon Concrete/Plaster Pool
    Pentair WFDS-26 - Installed Spring 2012
    Pentair Quad DE 100 - Installed Spring 2012
    Pentair Kreepy Krauly 820 - In Service 05/26/2013
    K-2006 Test kit, Intermatic P1353me Digital Timer, Stenner 85MHP5
    Jun 2014
    Roseville, CA
    345
    Re: Leak - How hard to fix? Pics inside
    It looks to me that you can unscrew the coupler, then unscrew the pump fitting. Probably Teflon tape may snug it up, but don't over do it or you might crack your fitting.
    There are also PVC thread sealants, but read the directions carefully. You want "seal", not "bond", in case you have to dissemble some day.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    reindeerboy's Avatar
    May 2008
    Jamestown, ND
    519
    Yep, its a union there which is good. Really you just unscrew the union, pull out the pump and unscrew the pipe into the pump. I would then clean it up, use some silicon 810 caulking, which is 100% waterproof, to goop that around the threads and put it back into the pump. Reconnect and let sit for an hour. Then fire it up!
    Chad R.
    POOL SIZE: 16 x 32' Vinyl lined pool. 22,000 gallons. 8' deep. 2009 Hayward 1.5 HP Super Pump. Hayward S310S 30" 500 lb Sand filter. 1 skimmer and 2 returns. Solar Blanket.
    Pics of my pool: http://s307.photobucket.com/albums/nn312/reindeerboy/
    Jun 2013
    Erie pa
    68
    Just unscrew the union,tighten the piece in the pump and reattach the union.
    16x32 vinyl ig with foxguard steel walls,gli liner ,hayward de filter,hayward heatpro heat pump,hayward colorlogic 4.0 led.pentair circular weir skimmers.hayward sharkvac xl robot,gli mesh cover.polk atrium speakers,sonos music system.erie pa.
