Household bleach vs store bought liquid chlorine
Welcome to TFP!
Nothing wrong at all using liquid chlorine vs. "household" bleach. They contain the same active ingredient, just at different strengths. The higher concentrations will lose strength quicker than lower concentrations which is why product turnover is important. The pool store likely has a much better turnover on this product than a "Big Box" home improvement store, so you are probably fine purchasing it at the pool store. As a test, dose the liquid chlorine according to what PoolMath tells you for the % concentration of liquid chlorine you are using. After about an hour, retest FC. If the FC is at the target you expected after the addition, you're fine. If not, then the liquid chlorine has lost some of its strength.
Plus, to add to what Bo said - many areas of the country do not have "store bought liquid chlorine" available. Sun belt states Florida, Texas, Arizona and the like it is sold on every corner. I would have to drive hours to find any.
Your case is not quite typical I dont think.
We recommened bleach simply because it is usually a little cheaper and easier to come by than the more potent liquid chlorine.
the active ingredient of Sodium Hypochlorite is exactly the same between the two.
That is an excellent price on the LC, go for it!
