Thread: FC Use During the Day
    May 2013
    Falls Church, VA
    41
    My CYA has been low and I have added 30 oz of conditioner so far. The last was just a couple of days ago. So, that application probably isn't reading yet. Yesterday morning my FC was 0. I added enough bleach to bring it to 4. At 1 pm the FC was 0 again. I elevated the FC 8.5 a dusk. Did an OCLT and this morning FC = 7.5 and CC = .5. Is this extreme use in the sun because my CYA is low?
    FC - 7.5
    CC - .5
    pH - 7.8
    TA - 70
    CH - 250
    CYA - 30 (registers lower but just added conditioner)
    11.5k gal, IG Plaster (2001), 1.5 HP Pentair Ultra-Flow Pump, Purex Triton FNS Plus 60 sqft DE filter
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: FC Use During the Day
    With little CYA chlorine can be totally lost to,the sun in hours.
    Support the site
    Isaac-1's Avatar
    SW Louisiana
    6,711
    With a loss of 1.0 ppm overnight with the OCLT if it was done correctly from from dark (twilight or so) at night until dark in the morning, you may have something trying to grow due to the low FC. I would suggest repeating the OCLT and if you get a 1.0 or higher FC drop again, begin a SLAM procedure. Pool School - SLAM - Shock Level And Maintain
