Results 1 to 13 of 13
Thread: New to pool, new to forum
    May 2015
    riverside, ca
    8
    New pool guy here. Pool started great, now not so much. Here's my question, the piping that goes into my filter cartridge housing is leaking. What do I use to seal the leak? Will basic pvc cement work?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: New to pool, new to forum
    What kind of equipment is it? What kind of plumbing? Is it a union, elbow, tee? A pic would help.
    May 2015
    riverside, ca
    8
    Silly question, how do I post pics? Also, it is the pipe that goes directly into the filter housing. A Pentair CCP420.
    19.5k gallon, plaster, .75 WhisperFlo pump, Pentair ccp420 420 sq ft cartridge filter,aris Watermatic G1000 Chlorinator, Purex triton 400 mini max plus water heater
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Get a photobucket account and you can copy and paste the img link in your post.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Many pool fittings like filter housings, pumps, pool valves, etc. require the use of special CPVC glue when glueing to PVC pipe, not just standard PVC glue that is used between the white PVC joints.
    May 2015
    riverside, ca
    8
    DFW, TX
    24,514
    Those are union fittings, there shouldn't be any silicone or caulk on that joint. Unscrew the fitting and there is an o-ring in there that probably needs to be replaced. Looks like a Pentair filter to me. There is a pic of mine in my build thread in my sig.
    May 2015
    riverside, ca
    8
    This has a pipe that the union screw to that is already in the housing. That is where it leaking from. I did tighten the union and used Magic lube on the O rings
    May 2015
    riverside, ca
    8
    So if the leak is not in the union but in the pipe coming out of the filter, do I use the CPVC Glue.
    DFW, TX
    24,514
    I don't know how the pipe in the filter housing is mounted to the housing. I've never paid attention to that.
    According to this manual it is also an o-ring fitting
    http://www.pentairpool.com/products/...filters-27.htm
    There is a parts list, you should be able to find the manual for your specific filter and order replacement fittings.
    May 2015
    riverside, ca
    8
    Pooldv, you rock! Thank you so much, this info is invaluable. Sorry it took so long to respond, working 3 jobs keeps me pretty busy these days.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    BTW welcome to TFP !
    DFW, TX
    24,514
    Busy indeed! Gotta make that pool money!
