Thread: Need help. Buying Intex Saltwater System
    May 2015
    torrance
    5
    Have a 12' round pool and my saltwater generator got that dreaded 91 low salt, even when the level is fine. Basically a design flaw in that flat black plug going into the cell unit. It will break and you can't avoid it.
    Anyway my question is Intex has 2 brand new units 28667EG 7,000 gallons and 28669EG 15,000 gallon unit. Found the units on sale at the same price. Which won should I buy? Will the higher gallon one last longer? Any other difference? Help line was not helpful.
    Thanks in advance
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Need help. Buying Intex Saltwater System
    Yes, it should last longer because you will run it less.
