Results 1 to 16 of 16
Thread: Using Calcium Hypochlorite to shock pool
    May 2013
    Dallas, TX
    69
    I just used 4# of calcium hypochlorite to shock my pool, as I have developed mustard algae thanks to the rain floods in Texas. I should be reading about 25 ppm of chlorine, but my Taylor test kit shows almost no chlorine! It dropped my pH from 7.8 to 7.2. Why donít I register chlorine with the test kit?
    19,000 gal in-ground plaster pool; plaster older than 10 years
    In-ground plaster pool, ~18,500 gal, Hayward single-speed pump, Pentair 60 sq. ft. DE filter, Polaris 280 robotic cleaner, SPA, heater (seldom used), use Taylor K2006 series test kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Using Calcium Hypochlorite to shock pool
    Which test kit do you have?
    If it is the K-2005 the DPD chlorine test will bleach out at high levels, this is why we do not suggest it, instead the K-2006 has the FAS-DPD chlorine test which will read high level of Chlorine
    May 2013
    Dallas, TX
    69
    I’m using K2006 with the DPD test, and I have read chlorine levels in the upper 20s before with no problem.
    Chlorine is constantly being lost, to sunlight, to algae, to other contaminates in the pool. So you need to be constantly raising it back up.
    If you post a full set of water test results we can give you much more specific advice.
    May 2013
    Dallas, TX
    69
    Quote Originally Posted by JasonLion View Post
    I will run a full set tomorrow, but I added 4 pounds of 73% sodium hypochlorite at sundown and an hour later I got almost no pink when I used the DPD powder. Something is strange. My issue has nothing to do with sunlight loss. Iíll post a full set of reading tomorrow.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    If you have that much chlorine demand it's time to SLAM the pool.
    Pool School - SLAM - Shock Level And Maintain
    Support the site
    If you have a full algae bloom or an ammonia problem then losing all of your chlorine is to be expected.
    May 2013
    Dallas, TX
    69
    OK. Here is what I did. I did have mustard algae on the sides of the pool but the water was clear ... no green algae visible in the water. I was coming out of the winter with the pool and had periodically added chlorine bleach to keep some chlorine in the pool until I was ready to balance it for swimming. So, since my cyanuric acid was almost zero, I decided to use some pucks from the pool store. While there I picked up some packs of calcium hypochlorite to shock the pool (normally I shock with liquid bleach) and a bottle of diammonium sulfate that is supposed to kill yellow algae. I followed the instructions and sprinkled the algae stuff around the perimeter, followed by 4# + 1 gallon of 8% bleach.
    An hour after running the pool I was amazed to see no chlorine present in the pool. It ran all night and here are this morningís numbers:
    chlorine - 0
    pH - 7.4
    Total alkalinity - 40
    calcium hardness - 300
    cyanuric acide - about 50-55
    Iím thinking of now going back to the bleach shock treatment, and add enough bleach to bring the pool to 22 ppm chlorine.
    May 2014
    Franklin, NC
    9,184
    Read the directions on SLAMing your pool in the How To section of Pool School and follow that procedure completely to the end. No more magic potions form the pool store.
    • CC is 0.5 or lower;
    • You pass an OCLT (ie overnight FC loss test shows a loss of 1.0 ppm or less);
    • And the water is clear.
    When all three are true, then follow the additional directions for Mustard Algae.
    Support the site
    Saturn94's Avatar
    Mar 2015
    Virginia
    496
    It looks like the stuff you added to kill the mustard algae may have added ammonia to your pool, which will eat up CL big time.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I don't know, but I would think the Sulfate could act as a Chlorine Scavenger. Does your kit have the FAS/DPD FC/CC test? If so what was your CC level?
    Essential Links:
    May 2013
    Dallas, TX
    69
    Quote Originally Posted by Patrick_B View Post
    Almost none. 0.5 CC.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Diammonium sulfate, sold as Yellow Out, creates an extreme chlorine demand. Read more about it here .
    Love TFP? Become a
    TFP Supporter!
    30,403
    Pool_dufus
    TFPC tenant - Never put chemistry in your pool when you do not know the outcome
    TFPC Tenant - Pool Stores can and will sell you most anything....whether it helps or hurts your pool.....they just don't know any better
    Logic would then encourage us to stay out of pool stores if we want to manage our water via TFPC.
    That may come across as being kind of a you-know-what, but it is factual and advice we teach every day. We must not be emphasizing it enough.
    38,251
    The CYA dropping to zero points to an ammonia conversion ... Which equates to high FC demand.
    Plus sounds like the products you added also result in a high FC demand.
    Time to start SLAMing with bleach, and lots of it to remove the chlorine demand.
    May 2013
    Dallas, TX
    69
    Yes, it was the Yellow Out compound that caused my problems. I have now added bleach and gotten my CL level back up into the 20s. With the constant tropical downpours we are having its going to be difficult to hold the shock level up, but I already can see come effects on the yellow algae. Thanks to everyone for their comments. I have learned my lesson. Stay out of the pool store!!
