Results 1 to 15 of 15
Thread: Helpppppp!!!!! Skimmer install
    May 2015
    Lynbrook
    9
    Angry Helpppppp!!!!! Skimmer install
    Hi I'm new I have been taking care of my above ground pool for the past 5 years now with no real issues went to get my pool open today and notices a crack in the skimmer it was a harsh winter so i get it.... So i went to the store and purchased a hayward skimmer with wide mouth conversion I go to put it together and install it but it seems none of the screws go in all the way and i am turning with all that i got long story short its leaking so i have to start over what am i doing wrong. Thank you in advance for the help
    Casey's Avatar
    SW PA
    10,444
    Re: Helpppppp!!!!! Skimmer install
    Get a drill bit and pre drill holes to make it easier. My shoulder has not been the same since installing my wide mouth skimmer last year.
    Casey's Avatar
    SW PA
    10,444
    Double posted lol
    May 2015
    Lynbrook
    9
    Sorry bout double post I knew I missed something seriously the instructions are no help
    12x18 above ground pool
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Your other post is deleted.
    Essential Links:
    Casey's Avatar
    SW PA
    10,444
    Quote Originally Posted by Frankiefoureyes View Post
    Well, seems like all instructions for the DIY'ers in regards to above ground pools LACK big time. Most of my knowledge comes from 7+ years of installing and caring for the pools I've had. I spent 5+ hours on mine, doubled up on gaskets and I'm still going to the Dr for my neck n shoulder. lol
    Did you get your leak fixed?
    May 2015
    Lynbrook
    9
    Gonna do it today last night was late when I posted
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Get a #3 Philips screwdriver after those screws. You are probably using a #2 as they are most common and it keeps slipping out on you. The #3 will give you the necessary torque and grip to finish seating the screws. How do I know this? Experience installing my Hayward skimmer. I tried using a #2 and had a little dribble of water no matter what I did. Broke out a #3 and "popped" them one more time and the leak sealed off.
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
    May 2015
    Lynbrook
    9
    i have alittle dribble of water i predrilled the holes and used a driver to put them in guess i will be hitting the hardware store tomorrow for a new screwdriver gave myself a nice blister on my hand trying to get those suckers in what a pain
    May 2015
    Lynbrook
    9
    Any suggestions gonna go grab a number 3 and see if it does anything otherwise I'm calling someone
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    I'm still on the #3 bandwagon. That's all it took to finish sealing mine off.
    May 2012
    Montville NJ
    545
    I just re-installed my non widemouth skimmer (new liner).
    1) Use a good screwdriver of the correct size.
    2) I use LIBERAL amount of "pool lube" on all gaskets, fittings, O_Rings, etc. Leslies sells it in a tube. I buy 2 or 3 tubes of it a season.
    3) If you use pool lube, get all of it off of your hands before you try and turn that screwdriver.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    May 2015
    Lynbrook
    9
    Just an update haven't had a chance to get to it yet gonna hit the store today for a screwdriver and pool lube
    May 2015
    Lynbrook
    9
    Sorry For late post so I lubed the gasket up and miraculously it all lined up and is nice and dry thank you all have been enjoying The pool since
    Casey's Avatar
    SW PA
    10,444
    Sweet!
