Thread: Which Ebay solar heater would you buy?
    Apr 2015
    Waterford, MI
    133
    Wifie is making me order solar heaters... so far these are my 2 options. (If you have others I should consider please post them.)
    1.) http:// http://www.ebay.com/itm/XLong-Inground-Above-Ground-56-x20-Solar-Energy-Swimming-Pool-Sun-Heater-Panel-/371295952914?pt=LH_DefaultDomain_0&hash=item5672f6a012
    2.) http://www.ebay.com/itm/48-x-20-Ingr...item567338ebf2
    I would think they are both relatively the same, ones 56" vs. 48", biggers always better?
    Michigan - 24'x54" AG, approx 15,000g, 2 center drains, Cartridge filter, Aqua Pro 2hp, 2 speed pump 3.5a@1725w / 10.5a@3450w, AquaCal TropiCal T90 heat pump, Hayward Salt & Swim SWG, Poolskim, Aquabot Rover Jr.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Which Ebay solar heater would you buy?
    I am happy with mine. Details in sig, and pics in build thread. Yes, more surface area means more heat.
    Orlando, FL
    690
    Bigger is better for solar!
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Isaac-1's Avatar
    SW Louisiana
    6,711
    As others have said, bigger is better, it is all about surface area, and to provide effective heating you need solar heater panels at least equal to 50% of the surface area of your pool. Otherwise it is a bit like trying to heat a house with a plug in cube heater.
    As to these ebay solar panels, I consider them ok for seasonal pools where they will be stored in the off season in a climate controlled location, I also view them as semi-disposable, if you get more than 3-4 years out them them consider yourself lucky. To a degree this is a matter of you get what you pay for, but beyond a certain price point you are paying for the 10-15-20 year warranty.
    Ike
    p.s. pooldv, the Techno-Solis panels, are a lot more beefy than these ebay panels. A 4x12 techno-solis panel has a dry weight of 29 pounds, or another way about .6 pounds per sq ft dry. I suspect these panels are around half as heavy, which is the approximate weight of the 20 ft x30 inch Eco-Saver panels on Amazon
    Apr 2015
    Waterford, MI
    133
    I did figure these to be somewhat disposable. 80sq.ft for $175 is cheap cheap.
    You could not make a system yourself for that price. I have a 4x8 cpvc solar panel project I started but set aside for a number of reasons, but cost compared to these Ebay solar panels was one of them.
