Thread: Plans for Outdoor Kitchen
    Scottaustin26's Avatar
    May 2015
    Houston, TX
    32
    I'm going to be building a outdoor kitchen in the next few months. I'm pretty good with AutoCAD, so I thought I'd give it a try. Tell me what you think!
    14.5K gallon IG plaster pool, 1K gallon spa, dual 2hp Jandy pumps, 60 sqft DE filter, 400K BTU NG heater. Dual waterfalls, Jandy Aquapure SWG, Polaris cleaner with 3/4 HP pump, Aqualink RS. See my pool here.
    Thanks!, Austin
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Plans for Outdoor Kitchen
    Looks good to me. Like the fact that you have lots of counter space. It will come in handy.
    rodog123's Avatar
    Nov 2013
    Pearland, TX
    308
    May I ask what instructions are you using to build the frame? I've seen symphonybbq.com are you using something as a guide? I'm not very handy.
    Completed 38'X21' IG Free form pool approx 18.5K gallons, sports pool w/spa and tanning shelf 3.5-5.5 ft. Jandy Cartridge Filter, Jandy stealth pumps, Jandy LXi Heater, I aqualink, Inline chlorinator. Click to see My Pool Build
    cwescapexlt4x4's Avatar
    Jul 2014
    Litchfield Park, AZ (PHX metro area)
    461
    I'd be inclined to move the fridge to the right and move the grill/side to the left IMHO. But you know better on utilities at your location than I.
    Chris - aka cwescapexlt4x4
    (Build 8/26/14 - 10/17/14) in-ground Presidential Pools 15K gallon salt water pool Pentair Inteiliflo pump, Regal Blue Pebble, Clean & Clear filter, in-floor cleaning,
    LED light, 3' sheer spill, 2 benches, large Baja step. / Pergola by Booth Built 19W x 14D // Outdoor Kitchen, W/Primo grill and BBQ Coach kit for the island.
    That looks identical to my ODK except my is an L shape 16 ' x 7 ', and the fridge and sink are swapped. Like Bo says, you'll need the extra counterspace, i run out all the time. I used Google sketchup to draw up my plans and it came out identical to the drawing. I'm very visual so i need to see the placement of everything before i commit. You can checkout my design in my signature. Looks good!
    20k Inground StoneScape mini pebble Tahoe Blue pool/spa combo. Intellifow VS 3050 / Intellitouch Control Panel 4 circuit / Pentair 24" Water Fall feature / Pentair Cartridge filter / Solar / Raypack 400k Gas Heater / Starite Max E 1.5 HP jaccuzi Pump / Sta rite Booster pump / Polaris 380. Click Here to see Outdoor Kitchen Fireplace Build
