Results 1 to 11 of 11
Thread: What percentage do you run chlorine production at?
    Scottaustin26's Avatar
    May 2015
    Houston, TX
    32
    I'm a new pool owner, and the pool has a Jandy Aquapure SWCG.
    My pool is currently running at 90%, is this what most people do?
    14.5K gallon IG plaster pool, 1K gallon spa, dual 2hp Jandy pumps, 60 sqft DE filter, 400K BTU NG heater. Dual waterfalls, Jandy Aquapure SWG, Polaris cleaner with 3/4 HP pump, Aqualink RS. See my pool here.
    Thanks!, Austin
    Re: What percentage do you run chlorine production at?
    Every single pool is different. The only way to find out what is right for your pool is to measure the FC level, if it is low turn up the percentage, if it is high turn down the percentage. Over time you can zero in on the correct setting.
    May 2015
    Houston, TX
    32
    Ok, I saw the water balancing article after I posted that, so I guess I'll just have to test the FC.
    Thanks!, Austin
    ffournier's Avatar
    Apr 2015
    Houston Texas
    43
    I'm not familiar with the Jandy AquaPure, but if it's properly sized for your pool, I would say 90% is going to be way to high. I have the Pentair IC40 and the most I ever have to run it is 40%, with 20 to 30% being more the norm. I'd set it at 50% and see were that gets you. You may want to check your chlorine daily till you get it stable.
    25K gal saltwater gunite and Pebble Tech plus built in spa. Features-Weeping rock wall, and fountains. All Pentair equipment. Main pump- Intelliflo 4/160. Feature pump- Intelliflo 2hp single speed. Aux cleaner pump-Pentair 1hp. DE filter, Pentair heater, Glacier GCP210 pool chiller.
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    I've been real happy with the new Aqua Rite T-15 I just put in. Last summer had to run old one at 75%. Started the new one at 50% and now down to 12% but watching daily for FC to drop. CYA is 30-50. Pool is 45,000.
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
    May 2015
    Houston, TX
    32
    Huh. Well, I havent really moved in to the house yet, and the owners left it on this, I just go to the house on the weekend to move boxes and stuff into it. I guess I'll have to get a test kit and see what's going on.
    Thanks!, Austin
    ffournier's Avatar
    Apr 2015
    Houston Texas
    43
    Just read your pool info. If they've been running those waterfalls with any consistency, then they may have to run it at 90%.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Quote Originally Posted by ned8377 View Post
    Isn't it recommend running a 70-80ppm CYA for a SWCG ??
    Solar Blanket, Well Water, Borax Added. 68
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi Scott,
    here is some useful reading for you both regarding setting up your SWG and the recommended levels to maintain your pool. Im sure you will have a lot more questions so please feel free to post them when they come up.
    TFTestkits.net is an excellent resource for a top notch test kit, which you will definitely need. The TF100 is the best bang for the buck.
    Here is a link to recommended levels. If you will keep your chemistry balanced to these recommendations, you will not have any problems with it.
    Here is a link to the Chlorine/ CYA chart. You want to maintain your chlorine relative to the CYA level. This is the 1st building block of good pool chemistry
    Pool School - Chlorine / CYA Chart
    Here is a link to the Pool Math calculator. Its invaluble in determining how much of something you need to add
    http://www.troublefreepool.com/calc.html
    this should get you started... as time permits, please click on teh Pool School Button at top of the page, its really important sort of understand at least what some of the things are, such as TA, Calcium content, CYA, etc and the ABC's of Pool Chemistry will get you started.
    Pool School - Determine Pump Run Time
    Divin Dave,
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    The pictures of your pool are impressive. All things considered, that is easily close to a $100,000 pool including all the decking and extras. I noticed, though, that there are a lot of trees hanging over the water and the rocks have a lot of crevices where algae can grow. That may explain why they were running the SWG so hard.
    Jul 2013
    Waxahachie, Tx.
    445
    The three main variables is speed of pump, run time per day and a salt cell that is sized properly. Then just use a systematic approach to dialing it in. You will probably be checking the FC everyday until it's fine tuned.
    My pool likes 1200 RPM, approx 6 hours a day at 40-50% desired output with current weather conditions. Mid to late summer usually requires 60% output
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
