Results 1 to 8 of 8
Thread: pump leak from the bottom of the casing
    bbecky75's Avatar
    Apr 2010
    Jasper, Alabama
    95
    Hi, I have a jacuzzi 1.5 speed pump that is leaking from the casing. Any suggestions on where to begin?
    30' Above Ground 18,000 gallons, Sand Filter, 1.5 hp Jacuzzi Pump
    Re: pump leak from the bottom of the casing
    Most likely the seal or housing gasket.
    Support the site
    bbecky75's Avatar
    Apr 2010
    Jasper, Alabama
    95
    Thanks, I thought the same thing. Do u think magic lube would work? It worked on the housing seal.
    Lube won't fix a bad pump seal. You would need to replace the seal.
    Support the site
    bbecky75's Avatar
    Apr 2010
    Jasper, Alabama
    95
    OK thamks.
    bbecky75's Avatar
    Apr 2010
    Jasper, Alabama
    95
    Hi all,
    Can someone help me find replacement parts for my Jaccuzzi pump. Model # 15LRC-5-S1/B
    I think I need the O-ring for the casing and the shaft seal.
    bbecky75's Avatar
    Apr 2010
    Jasper, Alabama
    95
    Hello,
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    JACUZZI PUMP LR,LVL,LRDV pool pump parts,Discount parts for JACUZZI pumps
    I believe part# 6 and 9 are what you are looking for.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
