Thread: Water finally clear what to balance first
    Bob_Funk's Avatar
    May 2009
    Seattle-It really rains all the time
    113
    Good afternoon,
    I finally have my water clear, pool has passed the ofcl test since Tuesday night/Wed morning & the sand filter finally cleared the last of everything out today.
    I am wondering in what order to start balancing things
    Cl 8
    CC 0
    Ph 6.9
    TA 20
    CH 240
    CYA 20
    I consider myself very lucky I found this site before the pool store found me-pool owner since Nov 2008- Stunningly clear 17,000 gal fiberglass pool, thanks to this site, installed in 1982-24" 3.1sq. ft sta-rite sand filter, 1 hp - 2 speed wisperflo pump-WFDS-4
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Water finally clear what to balance first
    Raise pH first. If you have any leftover pH up, use that. Otherwise, hunt down some washing soda.
    Then raise CYA using the sock method.
    Then recheck pH and TA and fine tune.
    See Recommended Chemicals for what does what and how to add it.
    Bob_Funk's Avatar
    May 2009
    113
    Thanks Richard, no one around here sells washing soda anymore, I have Borax & baking soda.
    I will get the Ph up with borax & then add 1/2 the recommended baking soda & re-test.
    My pool is in shade most of the day so I have always started the season with a CYA of 20 & use trichlor pucks when I go on vacation, keeps the chlorine level down.
