Results 1 to 7 of 7
Thread: New from NJ. Tired of faking it
    May 2015
    Cherry Hill NJ
    11
    So I have been reading this sight a little for the past few years and have come to the conclusion I had no idea what I was doing. Yes I knew bleach was liquid chlorine. But that was about it. After a horrible year of spending hundreds of dollars and still having a bad pool. Summer 2014. I am all in.
    May 2015
    Wildorado Texas
    252
    Re: New from NJ. Tired of faking it
    Welcome to TFP, SJS!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Well then, good for you!
    Welcome to TFP...Enjoy the forum.
    Essential Links:
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    good deal.
    in a couple months from now when you finally realize how eash and inexpensive it is, you'll be kicking yourself for not going all in last year!
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP! Congrats!
    Get one of the kits from the Test Kit Comparison, I use a TF100 test kit from tftestkits.net.
    Here are some intro Pool School articles to read while you are waiting for your test kit.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals
    Use PoolMath to figure out how much to add.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to the forum!
    May 2015
    NJ
    5
    I was having a hard time at first, it's a lot to digest. Watch a couple of YouTube videos regarding the bbb or tfp method especially if your more of a visual learner
    Whereabouts NJ?
    20k gallon IG vinyl pool.
    Hayward DE filter
    Hayward pump?
    Hayward 200 chlorinator
