Results 1 to 12 of 12
Thread: Pricing and Sourcing CYA
    Jul 2011
    North East
    135
    As the title states, what is the best price and source for CYA? Best I could find was 25 lbs for 68 dollars online.
    25,000 gallon Concrete/Plaster Pool
    Pentair WFDS-26 - Installed Spring 2012
    Pentair Quad DE 100 - Installed Spring 2012
    Pentair Kreepy Krauly 820 - In Service 05/26/2013
    K-2006 Test kit, Intermatic P1353me Digital Timer, Stenner 85MHP5
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Re: Pricing and Sourcing CYA
    I like the Walmart brand in 4 lb. jugs with a purple measuring cap. Dissolves really well. I think 4 lbs. was 16 bucks.
    25 lbs for $68 is a very good price.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    If you don't need a large quantity, Lowe's has 4 lbs for about $17.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I buy mine at Lowes, since it is only generally lost through water replacement and not evaporation, there is no real need to stock up
    p.s. why would you want 25 pounds anyway, that would send your CYA to 120 ppm assuming a fresh fill, which is nearly double the suggested level for an SWG pool and three times the suggested level for a manually dosed pool
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    If you Google "25lb stabilizer" you can find the same thing for $53.99 from backyardpoolsuperstore.com. If you buy $100 of merchandise from them, shipping is free. Might be worth it if there's something else pricey they sell that you need.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Jul 2011
    North East
    135
    Quote Originally Posted by Isaac-1 View Post
    Buying in bulk generally always lowers the cost of the goods being purchased. Just because you buy 25 lbs doesn't mean you can't save it for next season
    My pool always seems to need CYA every opening.
    Quote Originally Posted by gtemkin View Post
    Thats where I found the listing for $68. For some reason the other result didn't show up earlier. As far as I can tell, the only difference between the two are the containers. One being a bag vs a plastic bucket with a lid. At $2.15 a pound that is the best deal I've seen by far.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    so the next question would be, does CYA lose like chlorine? if its sits in a bucket for 2 years will it go bad?
    Saturn94's Avatar
    Mar 2015
    Virginia
    499
    I've had CYA stored in a shed for 2 seasons with no problems. I suspect the shelf is pretty long as long as it's kept dry.
    Ah....just found this;
    http://www.bpspool.com/MSDS/Accessor...ric%20Acid.pdf
    It says, "Shelf Life Limitations; Unlimited"
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    Jul 2011
    North East
    135
    Quote Originally Posted by cowboycasey View Post
    When I first started out I asked the same question and I believe the response was as long as it is stored in an appropriate place it will last without issue. I cannot confirm but that is what I remember.
    Jul 2013
    Fletcher, OK
    3,353
    well that makes it easy, 25 pounds...
    I went though over 100 items and after being on this site the only thing we would need is CYA just crazzzzy
    Pool Chemicals
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    thats a very good price. It comes out to 2.72 lb.
    Walmart is the least expensive in store price that I personally run across, and it equates to 4.00 lb.
    Divin Dave,
