Thread: New liner installed noticed something poking up into the liner floor.
    Jun 2010
    Southern Alabama
    41
    Looking for some suggestions on what ask for to be done.
    I had a new liner installed about 3-4 weeks ago. I found a spot on the floor where something is poking from the underneath and I am afraid after sometime the liner will rip.
    Is it reasonable for me to make sure they remove the liner and fix that spot, leave it, or???
    Any suggestions on what you would ask for And or settle for, will be appreciated.
    Thanks
    16' x 40' inground Vinyl liner pool. Has a depth APX of 3 1/2' to 8'. Pool also has a right angle APX 4'10' on shallow end. in Southern Alabama. It is not covered with sun on it most the day. SWG. Apx 31k Gallons, Sand filter with 1 HP Pump. Don't know the flow rate.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: New liner installed noticed something poking up into the liner floor.
    I would not settle for less than them coming out to address it. Get whatever they determine in writing if they say it doesn't need removing. That could be a problem for sure.
    Essential Links:
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    WHATEVER it is will surely cause you grief.
