Results 1 to 19 of 19
Thread: Frog system and getting rid of this system
    May 2015
    Hampstead, Maryland
    11
    I am in real help with how I eliminate the frog system! I am so upset and sorry to be blunt but extremely ****** at the company Leslie's Pools supply. I had started an order for 12 pack of the frog bac pac that was $215.99 but they were offering 20% off on orders placed thru Monday which would have saved me $43.20. In the meantime that I put the items in my cart I thought I had posted a post asking for advice on how to stop using the frog system. Since it is connected to the filter I wasn't sure if it was possible to bypass it or eliminate the frog. I wasn't sure if this would require me to buy a new filter or what I needed to do. I had also asked for advice as to chemicals I should use to replace them. I was attempting to see if I had any responses to my post but honestly couldn't even find my post so not sure if I did it correctly or if this post will even be seen. Anyway in the meantime, Leslie's increased the price of the 12 pack to $443.99 which is more than double the original price. How does a company more than double sales price in less then a couple hours. Please, please let me know how I can eliminate the frog so I can move on to a clear & safe pool. Any advice would b greatly appreciated!!'
    30,431
    Re: Frog system and getting rid of this system
    Simply take the refill out of the frog and never put another one in. Others will tell you how if you want to remove it completely.
    Meanwhile, read "The ABC's of Pool Water Chemistry" up in Pool School. That'll get you started understanding a bit about what we teach and ask us lot's of questions. You will get lots of answers.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Welcome to TFP! This is how we maintain pools.
    TFPC for Beginners
    Here are the Recommended Levels for your pool.
    Here is the Water Balance for a saltwater pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Just don't......FEED..........the frog!
    Donldson's Avatar
    NW Ohio
    2,917
    Quote Originally Posted by wnnbtrvlr View Post
    If you really want to be happy about removing the frog, there is only 2.2 lbs of trichlor tabs in a bac pac. In bulk you can get the same trichlor for $3/lb. So there is less than $7 worth of chlorine in those $20 bac pacs (how Leslie's raised the price that much I don't know, I think it was a mistake). Add that to the mineral pac adding silver and copper to your water, and trichlor adding a bunch of CYA and it is just a terrible system all around! It was installed on my pool when I bought the house and I ripped it out as soon as I found TFP.
    pooldv posted some great links to give you an idea what TFP is all about and what it takes to maintain a Trouble Free Pool. It can be overwhelming at first read, but I promise you that it actually turns out to be really simple after you give it a try.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    You say it's part of the filter. I've never heard of that. Got a picture? They are usually just a little system that is connected online after the filter.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Jul 2014
    Peoria, IL
    389
    Quote Originally Posted by n240sxguy View Post
    That is what I am sure they mean. The frog is pretty much like a nature 2 as far install goes.
    As stated pull the insert out and move on to TFP method and enjoy the massive amounts of $$ that will stay in your bank account.
    Post up a picture and we can probably help you remove it from your plumbing system if you so choose.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by bdex View Post
    I didn't know if I missed something and they made some new monstrosity that was a filter with a cartridge port or something. Anything to keep you on the crazy pool store train.
    Shouldn't be any problem to remove. I ripped mine out a couple days ago when I installed my new swg.
    May 2015
    Hampstead, Maryland
    11
    Will do! Thanks so much! So just to be clear, you can leave the Frog attached to the filter empty, or should I use the old mineral pack and an empty bac pac (the chlorine pack)! Thanks so much for your help. I'm so glad I foun
    May 2015
    Hampstead, Maryland
    11
    I will load a pic of the filter Ina bit but I have to say you all have made me feel a lot better. Yesterday when I went online to make the purchase of the 12 pack of bac pac and they had more than doubled the price I cried for hours. I'm on a limited income so this was quite a blow. Sounds ridiculous I know but my pool gives me a lot of happiness in the summer and our season is much too short to begin with. I actually called Leslie's and told them how ridiculous it was since I had bought one on the 20th and it was only $18.99. I will share a pic of what I was able to screenshot of the price increase yesterday and a pic of filter shortly. I have a lot of reading to do but I feel like
    May 2015
    Hampstead, Maryland
    11
    Sorry, I feel very encouraged by this site and all of your support! Thanks so much.
    May 2015
    Hampstead, Maryland
    11
    May 2015
    Hampstead, Maryland
    11
    Original purchase on 20th of one bac pac. ATTACH]36927[/ATTACH]
    May 2015
    Hampstead, Maryland
    11
    Notice of price increase and new cart pic with price increase shown:ImageUploadedByTapatalk1432578713.444732.jpgImageUploadedByTapatalk1432578739.727057.jpg
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,196
    Bleach at WalMart is a lot less expensive than that. With one of the recommended test kits and bleach you can keep your pool sparkling. OK, you may need a few other things, but the expensive frog is not included.
    Support the site
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,620
    We have your back!
    Just take everything out of the system. There is no need for it. There is no need to even have the empty packs in it.
    We can and will save you SO much money you will be oh so happy you found TFP!
    Next read the links provided. You will find that we are all about YOU taking care of your pool. Easy and cheap! There are really only three things you will have to buy:
    1. a good test kit-look at my siggy below for the link to them. The TF-100 is the best bang for the buck.
    2. bleach/chlorine-yes like you can buy at Walmart! Just plain bleach, greater value, no scents or anything. Shop around for your best prices. Some find it at Walmart, some find it at Sams, some at the local pool store (that is just about the only thing they get from there). I find my best price at my local ACE Hardware up the road. Make sure it has the % listed and has a current date code.
    3.you might need to buy muractic acid to adjust your PH. We will not know if you need it until you get your test kit in.
    So now you know what to do. Step by step:
    1. find TFP-done
    2. ask questions-done
    3.order test kit-working on
    4. find good bleach price-working on
    When you get your test kit let us know and we can help you with the test and what you need to do.
    At first it feels like a lot but with time and reading and rereading you will know how to do it on your own. Until and after we are here for you!
    Kim
    April's Avatar
    Apr 2014
    KY
    138
    You can just leave the frog hooked up. If you DON'T put anything in the frog nothing is going into the pool so it won't change anything whether it's still hooked up or not.
    Basically your going to add bleach in front of the return instead of using the frog.
    18ft Round AG, Vinyl, 100LB Pentair Sand Filter, 1HP, June 2012, TF-100 w/SpeedStir
    May 2015
    Hampstead, Maryland
    11
    Thanks everyone! Going to order my test kit now and start reading! I will be in touch!
    Jul 2012
    Tallahassee, FL
    30,620
    I look forward to seeing your first test results!
    Kim
