Thread: Fencing for above ground Intex pool
    Jun 2014
    Sacramento, CA
    1
    Can anyone recommend a brand of fencing for attachment to the side rails of an Intex Ultra Frame pool? All of the photos for such fences show them attached to pools with more substantial top and side rails. If anyone has successfully installed such fencing, I'd sure appreciate hearing about it.
    Intex Ultra Frame 18'x52" SW
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Fencing for above ground Intex pool
    Welcome to the forum!
    While I don't know, there is likely someone here who has added that or similar. Enjoy your time on TFP!
    Essential Links:
    Orlando, FL
    690
    Search the forum for Intex pool fence and you will find things like this...http://www.troublefreepool.com/threa...e-with-Fencing
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
