Results 1 to 11 of 11
Thread: Sudden pH rise
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    Sudden pH rise
    We had been using a solar cover to keep the water temp around 82 degrees, but fall finally arrived, and we had to give it up. pH had been a stubborn 7.2 - seemed like the solar cover was surpressing the pH. TA was 100.
    Took solar cover off 2 days ago, started shocking due to a bottom dwelling algae/pollen problem- I was not keeping FC high enough- I may have been misreading the CYA tube.
    Now, pH is 8, with TA only gone to 110.
    Changes: No solar cover
    Temp of pool dropped 10 degrees in two days
    1.5 inches of rain
    switched from cal-hypo 65 to bleach for chlorine
    air temps dropped 20 degrees
    Question 1: On reading the CYA tube- when is the dot "gone". I was adding the test water with CYA reagent to the tube until the dot was completely obscured- not even a hint of a shadow. That gave me a CYA reading of 45. Keeping my FC at 5 based on that reading allowed algae to happen twice- though both times there has been contamination added to the pool around the same time- a fact of life in the country.
    If I read the tube at the point where the dot is mostly obscured, just a shadowy outline, I get a CYA of 60- a pretty big difference. Which one is right?
    FC is currently at 13,
    CC=0 (I hardly ever get a reading there, even when I cannot see the bottom of the pool),
    CH=150,
    TA=110
    Water is somewhat cloudy with a yellowish-green tinge and the bottom has lots of pollen/algae (probably both, pollen is a fact of life here). However, about 1/3 less than the day we took the solar cover off and did a thorough vacuum and backwash
    My shock level depends on my CYA level, which I was taking to be 45 and was using a shock target of 16
    Question 2: Do I need to do anything about the pH yet? Is that large of a jump common with shocking? When I was using Cal-hypo 65% to shock (a week ago) and with the solar cover still on, I only saw the pH go to 7.5, but I was shocking to 16- same level as now.
    Picture coming shortly.
    28 ft round Doughboy Sand Dollar II AGP, Aug 2008: 4 ft shallow, 6ft deep end: 24K gal approx Hayward Power-Flo Matrix
    1&1/2-HP 2-SPD Pump, Hayward 27-Inch Sand Filter with a little DE -(2) 4ftx20ft Solar Bear AGP Panels w/ Goldline auto-controller, 50ppm Borates And some day, maybe this year, a DECK!!!
    30,419
    Re: Sudden pH rise
    Hey, Amjohn,
    Lower your pH below 8 sooner rather than later. anywhere from 7.2 to 7.8 is acceptable but 8 is too high. Use muriatic to bring it down to maybe 7.4 to be ideal.
    Probably somewhere in the middle but favoring the 45. You should not be able to see the dot but it sounds like you are making sure it's obliterated. The test is never precise and I'd say you are around 50ppm which is just fine.
    From your pics, it appears to me you have some mustard algae forming in your pool. That's not an analysis but a guess based on my experiences. I would suggest you do an ovenight FC loss test (post back if you don't know exactly how to do that) and my guess is you'll find youneed to shock the pool.
    Once it's cleared I would also suggest you keep your FC a little higher than recommended (say maybe 20%) for your CYA level. I believe you will then have no further problems with water clarity.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Sudden pH rise
    Hi amjohn,
    Quote Originally Posted by amjohn
    You're not the only one who has had problems learning how to read the CYA test!
    See if this visual helps (scroll to bottom pf page):
    http://www.taylortechnologies.com/Chemi ... ntentID=44
    You're done SLAMing when:
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Re: Sudden pH rise
    Thank you for posting that link,
    I too have trouble reading the test. I thought my results were 80, only to have it professionally tested and got 108
    Thanks again
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    Re: Sudden pH rise
    Quote Originally Posted by meatloaf
    There is no reason to believe that the "professional" is any better at doing the test than you are. And given that they got a reading of "108" there is strong reason not to believe their result. (It is impossible to have anything like that kind of precision when testing CYA.)
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Re: Sudden pH rise
    I thought that result was a little high myself. Even my test strips (which I know are not very accurate) show a result of about 70-80.
    30,419
    Re: Sudden pH rise
    I want to say how strongly I agree with Jason's statement.
    Time after time on this forum, we find that the pool owner tests more accurately than the pool store. Sometimes because the owner is armed with a better kit but frequently because the owner cares more about his pool than the pool store.
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    Re: Sudden pH rise
    I have been shocking to FC=16 for the last two days. pH is 7.8 today. I will continue shocking, brushing, vacuuming, backwashing until things are as clear as they can get- however I always have some sediment in the bottom of the pool. We live in a rural area surrounded by hundreds of acres of pastures (literally) and this is peak ragweed season- you can see it blowing in the air. Every month is peak something season here.
    The clear picture with sediment was taken before the solar cover went on- all values normal, no CC, no FC change at night, and as you can see, no cloudiness. Right now, I would believe I have some algae along with the pollen, but I had very little FC loss last night- about 1. The water is still not clear, and there is still a fair bit of sediment on the bottom.
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    Re: Sudden pH rise
    Also, thank you Butterfly for the post of the Taylor site on how to read the CYA test- it appears that I was getting a little overenthusiastic in trying to "drown" the dot. It does also appear that my pool needs a little more FC than "normal" because we do have so much contamination.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Sudden pH rise
    Thank you for posting that link.......I too have trouble reading the test.
    Thanks again
    You're welcome meatloaf!
    Too funny! and, you're welcome amjohn.
    A couple years ago I had problems reading the CYA test. Sound familiar? :P Maybe I was trying to drown that dot, too! chem geek (Richard) gave me this link and it has been a great help not only to myself, but many others! Thanks Richard!
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    Re: Sudden pH rise
    Well, the pollen/mustard algae has been shocked away, water is sparkly clear. Turn out my CYA is 60 using the picture from Taylor technologies to match the test- that would explain a lot. FC is holding at 14 after a high of 16 two days ago- definitely very little loss there. Shocked for a week at 16-18.
    pH and TA are coming down a little- my eyeball return may aerate more than I realized. I pointed it down as much as I could, we will see if that helps.
    pH=7.5-7.8
    TA=100
    CYA=60
    CH=150
    Below are the after pictures: just a few minor deposits of something that is bright yellow. It looks granular, but poofs when I brush it. Pollen?
