Results 1 to 11 of 11
Thread: New pump and filter help needed!
    May 2014
    Mid-Michigan
    30
    New to the forum. This is the third season with our pool. It is a 20x40 igp about 35000 gallons. Getting the pool up and running this spring has been terrible. My sand filter is pumping sand into the pool, and having trouble getting the water clear.
    I need to replace the sand filter and would like to go to a cartridge filter and might as well try to save a little on my utility bill and get a new pump while I'm at it. Was thinking and clean and clear 420 for the filter, but not sure what to do for the pump. Still pretty new with the pool game and would like to get things sized right for my pool. Any help or suggestions on a filter and pump would be greatly appreciated.
    Steve
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: New pump and filter help needed!
    It is hard to give advice without know more about your pool setup. Having a detailed list of current equipment, plumbing and pool features would be a good start:
    http://www.troublefreepool.com/conte...efore-you-post
    Mark
    May 2014
    Mid-Michigan
    30
    Updated my signature. Is there any more info needed for a recommendation? My pump is warn on the sides and can't find it'd hp rating. Thanks in advance for any help. Thanks
    Steve
    20x40 35k gal, IG vinyl, Hayward sand filter, New Pentair Superflo vs pump, 220 btu heater, aquaclean EZ robot
    May 2014
    Mid-Michigan
    30
    Also I don't have a good test kit. I've been getting by taking samples in to the pool store. I'm intrigued by the BBB method but I'm a little intimidated and not sure how to start.
    Steve
    mas985's Avatar
    Pleasanton, CA
    11,737
    Ok so if you don't have any water features, almost any pump will do and the smaller the better from an energy usage perspective. The filter is a good start and if you like Pentair, a good paring is the SuperFlo 1 HP 2 speed pump.
    But give your location, do yourself a favor and put it a filter bypass and vacuum to waste functionality. This will make it much easier to open a pool with a cartridge filter. They tend to clog up quickly when opening a pool and it is a good idea to kill all the algae first in filter bypass and then vacuum the dead algae to waste so you don't have to clean the filter multiple times.
    Mark
    4knights's Avatar
    NE Kansas
    419
    Quote Originally Posted by sblattert View Post
    Don't be intimidated- take it slow, read pool school again, order the TF-100. Follow Marks advice and look at Craig'slist if your considering replacing the sand filter. I got a huge deal on my current DE filter. $125- for the heater, filter & Multiport valve. Even if I would have had to replace the grids it was a major savings over new.
    I really like this guys videos- https://www.youtube.com/user/MrDgvb1
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    May 2014
    Mid-Michigan
    30
    [QUOTE But give your location, do yourself a favor and put it a filter bypass and vacuum to waste functionality. This will make it much easier to open a pool with a cartridge filter. They tend to clog up quickly when opening a pool and it is a good idea to kill all the algae first in filter bypass and then vacuum the dead algae to waste so you don't have to clean the filter multiple times.[/QUOTE]
    Can you post a pic of what that bypass would look like? I would like to plumb in the new pump and filter myself. A pic or link would help. Thanks.
    Steve
    May 2014
    Mid-Michigan
    30
    I am also not married to any brand. All my stuff right now is actually Hayward. Is there a brand I should stay away from, or one you all recommend?
    Steve
    mas985's Avatar
    Pleasanton, CA
    11,737
    How is this:
    Mark
    May 2014
    Mid-Michigan
    30
    That is helpful thanks! Any thoughts on brand and size of cartridge filter?
    Steve
    mas985's Avatar
    Pleasanton, CA
    11,737
    The filter size (420) you mentioned above is fine for that size pool. Bigger is nearly always better when it comes to cartridge filters. As for brands, I have no particular favorite. All seem to be similar in reliability so go by price. On the Hayward side, I like the MaxFlo 1 HP 2 speed (SP2307X102).
    But I forgot to mention that you can just swap out the motor of your current pump for a two speed if you want to go that route.
    Mark
