Thread: Leaky Polaris 360 Hose
    May 2015
    florida
    2
    Hi,
    I have a polaris 360 with the large diameter hose. It does a great job but the hose keeps splitting and leaking so I have to cut off the leaky sections and reattach the hose. At $25 per six foot section it is getting to be an expensive repair. Is there an alternative to using the polaris branded hose?
    Thanks!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Leaky Polaris 360 Hose
    I would suggest replacing that section of hose rather than cutting and reattaching the same hose. Sounds like the hose is at the end of its life span and can spring a new leak at any time. I have a Polaris 360 and you should get a couple of years out of a new hose - minimum.
    May 2015
    florida
    2
    Quote Originally Posted by BoDarville View Post
    Thanks how long should the hose last? I replaced the entire hose about 2 years ago.
    Jun 2014
    Roseville, CA
    343
    It depends a lot on how smooth your pool surface is and the quality of the materials in the hose. It's a "wear item", so just figure on a segment or two every three or four years, but your "mileage" is unique to your pool.
    I've bought at Leslies, I've bought on line. It's pretty much all made in the same Chinese prison. LOL.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
