Results 1 to 10 of 10
Thread: I can't get Heat pump to flip on while running pump on low
    Hi, pool specs are in my signature.
    The other year I replaced my pump with a 2 speed SP2607X102S.
    I still only have 1 wire going from my pump to my Automation hookup, so I have to manually switch between low and high speed.
    Problem is that on low speed, the heater won't flip on, it just says flow, so there was almost no point to buying a 2 speed if the heater won't flip on and I don't think there is a way to automate it so that it flips to high speed when the heater needs to run.
    The pressure on low is 5, and the pressure on high is 15.
    Is there something I could possibly be doing wrong?
    The only way I can get the heater to flip on when on low is if I close the valve for the 3 return jets in pool and the valve for the 2 pool stair jets together at the same time.
    18' x 36" Ovalish 80,000 Litre Vinyl IGP. 2 speed 1HP Hayward pump SP2607X102S. 300 Pound Sand Filter. Summit Sum5 Heat Pump, Goldline Controls Aqua Logic P4 System, T-CELL-15 SWG, Aqua Pod Remote Control, Pentair 7845xx02 light.
    TF-100 Test Kit, SpeedStir Stirrer, Pool Chemist in training.
    Jun 2013
    Erie pa
    68
    Re: I can't get Heat pump to flip on while running pump on low
    My heat pump wont work on low speed either, the 2 speed pump was a waste of money.
    16x32 vinyl ig with foxguard steel walls,gli liner ,hayward de filter,hayward heatpro heat pump,hayward colorlogic 4.0 led.pentair circular weir skimmers.hayward sharkvac xl robot,gli mesh cover.polk atrium speakers,sonos music system.erie pa.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Check the manual for the automation system and see if it is capable of switching your pump speed. Also, you could check with the heat pump manufacturer to see if they have a recommendation for using their heater with a 2 speed pump. Maybe they have a different flow switch that can be used. Do you know where the flow switch is located?
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If there is a relay output from the heater for being on, it should be easy to rig an automatic speed change with a RIB relay, I did something similar on my solar heater.
    p.s. here is an archive thread where I posted on the subject http://www.troublefreepool.com/archi...p/t-57403.html unfortunately the photos are gone now
    Jun 2013
    Erie pa
    68
    How much is an automation system with that capability?it is a hayward pump
    Quote Originally Posted by Loudonno View Post
    So far that's how I feel, I never even get to use the low speed, would be nice since it is is quiet.
    Quote Originally Posted by n240sxguy View Post
    I don't even know what a flow switch is
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by Rockstead View Post
    Therein lies the problem. You'll either have to do a lot of studying or call the manufacturer. Everybody starts somewhere. It depends on your mechanical/electrical aptitude. If you want/need to learn something, you can. The Internet is a great tool. Use it.
    Jun 2013
    Erie pa
    68
    I contacted the manufacturer and hayward said the flow switch is designed to protect the unit and should not be tampered with.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    The SP2607X102S is a 1HP Super pump. The Heat pump is recommended to have about 47 gpm and no lower than 30 gpm. This is to protect the heat pump from low flow. Not recommended to adjust the pressure switch as it could cause damage to the heat pump. On low speed this pump will pump between 5-44gpm depending on the head pressure. A larger two speed pump like a 2HP two speed would do the trick. In this instance I like the variable speed as you can dial it in.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    I spoke with Hayward support. I got some good feedback.
    For the two-speed pump is wired to the Filter Pump relay for high speed and to Aux relay for low speed, then the Aqua Logic is set to control a two speed pump.
    In the Aqua Logic's Config Menu, Filter Config should be set to 2-speed, and Heater Config should be set for 'Allow Low Speed' = Disabled.
    During default operation, high speed mode is used whenever the heater is on.
    So this answer my question but unfortunately it's not a perfect way to use the low/high efficiently.
    I leave my pump on 24/7, if this were efficient, the pump would switch to high speed when the heater kicks on and then switch back to low when it doesn't use a device requiring it.
    In my case, I set my pool to 80, so my heater will always kick in to keep it at that temp. With this restriction, I have to set my heater on a schedule, so let's say 9-5, but it would be set to high even if my temp was already at 80.
    Outside the 9-5 schedule, I would have a 2nd schedule that runs on low.
    Does any other system of what I'm asking or has someone found a better way? Not that I would upgrade for this, but I'm just curious if there are more intelligent units.
