Thread: AGP cover blowing off
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    A friend of mine has a new Intex above ground pool that came with a cover. Wind is getting under the cover and blowing it off. Has anybody else had this problem and if so how can it be prevented. We tried putting a long 2X4 across the top of pool to hold the cover down but that didn't work. Any suggestions would be appreciated.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: AGP cover blowing off
    They can get clamps at Home Depot or lowes to clamp the cover on. That is what we did.
    http://t.homedepot.com/p/HDX-2-in-Spring-Clamp-80002/100027346
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    They undersize those covers a lot. You could order a bigger one, they are inexpensive.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Quote Originally Posted by Azgirl71 View Post
    http://t.homedepot.com/p/HDX-2-in-Sp...0002/100027346
    Those clamps are a good idea. Wish I had thought of that.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    My husband thought about it last year.
    Lisa
