Results 1 to 14 of 14
Thread: The pump and the skimmer basket
    May 2015
    Naples florida
    15
    The part that connects the actual pump to the skimmer basket is a screw on connection it leaks can't/ don't want to tighten any more shouldn't there be a seal there? I have pictures but am unable to upload them to this post. I have no history with this pump was purchased second hand trying to get the air leaks out and my psi and suction up. It is a waterway pump model sd-10 any help would be appreciated
    Jun 2014
    15,110
    Re: The pump and the skimmer basket
    Maybe it looks this this one?
    May 2015
    Naples florida
    15
    well sorta other they the trap assembly not being attached and my nut being a split affair with two Phillip screws
    Jun 2014
    15,110
    From a quick search on-line for your model number, it looks like most of those unions do indeed have an o-ring like the image attached. If there is a leak, you should have air bubbles in your pump basket lid, or maybe even see some water squirt-out when you turn the pump off.
    May 2015
    Naples florida
    15
    I wish I could figure out how to post the pics I have
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    You can upload pics to photobucket, then copy the IMG code and paste it here.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2015
    Naples florida
    15
    next one
    http://s300.photobucket.com/user/eric_andrews1/library/
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Cannot see them. You did not post the IMG codes.
    click on your pic on the right there will be codes. Copy IMG code
    Lisa
    May 2015
    Naples florida
    15
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I copied the individual IMG codes for you.
    Lisa
    May 2015
    Naples florida
    15
    how do you do that...Thanks
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I opened each picture. Then copied the IMG code you selecting all then pasted it here. Each picture has its own code.
    Lisa
    May 2015
    Naples florida
    15
    I have no idea what you just said LOL but thanks I know I asked how but...........
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    When you click on the picture it will give you several different links that you can use depending on what you are doing with them. There's html, img, and several others. Click img, it will copy it when you do that. Right click in your post and hit paste. Bam! Pictures.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
