Results 1 to 11 of 11
Thread: Ongoing High CYA Readings
    foxwlww's Avatar
    May 2015
    Elizabeth, PA
    3
    We are new to the forum and are very frustrated with the pool store at this point. Over the last three years, we have gotten into a severe issue with high chlorine demand and extremely high CYA levels. We were barely able to use the pool over the past two summers and have spent ridiculous amounts of money on chemicals to no avail. When we opened this year, we had purple residue on the walls of the pool and the under side of our winter cover. Based on prior recommendations, we drained the pool halfway. We dry vacuumed the purple residue from the pool walls with a shop vac and vacuumed out the purple debris in the pool to waste. We refilled with city water. After refilling, we are still getting CYA readings of around 100 ppm. Does that seem possible? And if so, does that mean we need to drain the pool halfway again before doing anything else? We are strongly considering switching to the BBB method this year.
    Vulpini440
    Our Pool is Vinyl IG, 30,000 Gal.
    DE Filter, Hayward EC65A with Hayward Superpump
    Single Speed, run continuously, Pool Install 1984, New Liner 2004
    Test Kit HTH 6-Way #91905 with CYA Test
    Pool Fill via City Water
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Ongoing High CYA Readings
    Welcome to TFP! What test are you using to test your water?
    the only way to lower CYA is partial drains and refills.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,868
    First, welcome to TFP
    Second, how are you testing the CYA? Getting your own quality test kit is a priority. There is a link in my signature to the test kit I would recommend.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    foxwlww's Avatar
    May 2015
    Elizabeth, PA
    3
    Thanks, we are using an HTH 6 way liquid test kit with the cyanuric acid reagent test vials. We performed the test twice and achieved about the same reading both times. We drained the pool half way after opening and then refilled with city water and still have the high CYA reading.
    Vulpini440
    Saturn94's Avatar
    Mar 2015
    Virginia
    499
    Quote Originally Posted by AimeeH View Post
    +1
    This is priority #1 IMO. Without it there's no hope of taking control of your pool.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    As previously mentioned. You should invest in a recommended test kit. Strips are not reliable. You can do another partial drain and refill. That is the only way to lower CYA.
    Lisa
    foxwlww's Avatar
    May 2015
    Elizabeth, PA
    3
    Thanks. We did purchase the recommended test kit, it is on the way. However, we are not sing test strips, we have the liquid test kit that uses the cyanuric acid reagent, and we performed the test twice. It would appear that the only option is to do another partial drain and refill???
    Vulpini440
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Yes. Keep doing your drain and refill cycle until you can break that 100 number. Once you are below 100 you can use pool math (the calculator on this site - link at top of page) to tell you exactly how much more you need to drain to lower to your final target CYA.
    When the CYA tests as 100 or more it could be well over that. It's definitely not unheard of especially if you have been following the pool store methods for years. Make sure you do not add any more chlorine products that have CYA in them. Dichlor powder and the chlorine tablets both add CYA.
    Right now, Liquid Chlorine (aka bleach) is your best friend. It will add the needed chlorine without any CYA.
    *edit*
    Here's the link for Pool Math. http://www.troublefreepool.com/calc.html
    Until you can get below 100 it's pretty hard/impossible to know exactly what the CYA level is so keep on keepin' on with the partial drain/refills until you get there.
    Moderators/Experts, would the diluted test be appropriate here and is anyone familiar enough with the HTH 6-way to know if that CYA test can be run with the diluted method?
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    CYA can only be tested reliably up to 100. Its defintely possible for your CYA to be actually way above that, which is why after your 50% drain and refill, you still see CYA of 100.
    Unfortunately, you've been pool stored and we see this same situation multiple times from different folks every single day.
    Sadly, the only remedy you have is to do another drain and refill as many times as necessary in order to get your CYA to a manageable level.
    Once you do that though, and armed with the knowledge of TFP which is based upon science and not sales pitch an bs like the pool store, you will never have to deal with this situation again. And you will find that maintaining a Troublefree and Algaefree pool is quite easy and inexpensive to boot.
    Quote Originally Posted by foxwlww View Post
    Divin Dave,
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,868
    There are instructions in this thread http://www.troublefreepool.com/threa...Kit-Directions
    For diluting a test for when CYA is over 90. That may help you get a clearer picture of where your CYA is.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Yes, it is possible that your CYA is still over 100, we've seen plenty of people with CYA of 300 or 400.
