Thread: in ground pool...safe to swim while pump is on?
    JenniferJuniper2's Avatar
    Mar 2015
    sacramento, ca
    134
    Question in ground pool...safe to swim while pump is on?
    Hello,
    I hope this isn't a stupid question, but I read it might be unsafebto swim while your pump is running. But our pump runs a) our waterfall and B) our (diy solar coil) heat system. As a kid I swam in our above ground (doughboy) all the time with the pump on and nothing ever happened. So what's the deal, is it safe?
    15k gal freeform sport pool with rock waterfall. Replastered 5/2016 with Tahoe Blue Quartzscapes
    Taylor FAS-DPD K-2006 test kit
    Jacuzzi 2002 J 310
    Re: in ground pool...safe to swim while pump is on?
    Any properly made in-ground pool is fine to swim in while the pump is running. Some above ground pool should not be used when the pump is running, mostly Intex pools.
