Results 1 to 8 of 8
Thread: pH and Alkaline
    Apr 2015
    Waukesha, Wi
    27
    pH and Alkaline
    I have an intex 18 x 48 pool (5455 gal) with SWG. I tested the water and the pH is at 7.8 and TA is showing 200 with test strips. I put in a pH reducer a few days ago, but no change. All the other chemical levels and chlorine are good. Any suggestions?
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: pH and Alkaline
    Get muriatic acid from Homedepot or Lowes. Do not get the "Safety" or "Low Fuming" versions.
    http://www.homedepot.com/p/Smart-2x1...8-HD/100119310
    http://www.lowes.com/pd_206474-34228...ductId=3024039
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: pH and Alkaline
    I would suggest a Basic Taylor K1000 test kit and a Taylor-TF100 FAS/DPD kit at a minimum. The strips are terribly unreliable. If you didn't mind spending a little more to get a full kit, then a Taylor K2006 or TF100 kit would be my suggestion.
    Essential Links:
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: pH and Alkaline
    You pH is right at the high limit of what we recommend. I would focus on maintaining pH over TA. Think of pH as the main tuning knob that selects the desired channel and TA as the fine-tuning knob that brings the selected channel into sharper focus.
    I would also recommend getting a proper test kit such as one of these Recommended Test Kits. A proper test kit is the price of admission to follow our practices. The multi-test strips do not have the precision needed to properly follow our methods.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: pH and Alkaline
    First suggestion would be ditch the test strips and invest in a recommended test kit. Test strips are not a good reliable testing source.
    Don't use PH down. You can lower TA by using muratic acid. It will lower your PH. You can read about it in pool school. Basically you lower PH to 7.2 which also lowers TA. Your PH will rise through aeration. Once it gets back to 7.8 you respect the process. Again your test trip testing could be lying to you.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: pH and Alkaline
    +1 on that test strip being worthless. You could stick your finger in the water and hold it up to the wind and get just as good a test result.
    Here is the process for lowering TA if you still want to, Lowering Total Alkalinity
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: pH and Alkaline
    Quote Originally Posted by pooldv View Post
    I love your analogy!
    Lisa
    Jul 2014
    Ottawa, Ontario
    25
    Re: pH and Alkaline
    I can attest to that! My test strips were telling me my TA was around 40. Had my friend test everything with his TF-100 kit and it was actually 170! Other items were off as well.. I now my have my own TF-100 and I'll go back to strips! Even now for giggles I'll test the water with the strips to see how off they are and sure enough... they are always off!
    Paul.
    15 x 30 oval above ground pool. 38,000 liters (10,000 gallons), Kodiak Salt System with Clearwater Technology SWG,
    Hayward Sandmaster SM2106TW Sand filter, 225lbs Design Flow rate 44gpm
    Hayward Vari-flo SP0714TC Multi-port valve, Hayward SP5715W 1.5hp pump single speed
    LOTS and LOTS of @!%@! trees!!!
