Results 1 to 8 of 8
Thread: Used sand filter
    May 2015
    Smyrna, ga
    17
    Used sand filter
    Happy Memorial weekend all!!
    I am looking at a sand filter in Craigslist to replace my current 24" sand filter to go bigger for better filtration. The filter in question is a Tagelus 100d. Never having opened my filter, I just want a good idea of what to look for in a used filter. I know the laterals are easily damaged, but is such damage normally visible. Cracked tanks are another thing mentioned, assume just filling with water will show this.
    I understand the multiport may require a new spider gasket and there likely is no way to tell.
    Other things to closely inspect?
    Thanks.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Used sand filter
    Look for cracks, and don't rely on a wait until filling it up. Check all the fittings for cracks and damage as well as the multiport. Plan on seals and gaskets like the multi-port you mentioned. Damaged threads...can't think of much else, but someone may. Good luck with it, hope you get a smashing good deal.
    Welcome to TFP!
    Essential Links:
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I don't know that brand, but be aware some spider gaskets are not serviceable, so check for parts availability before buying.
    May 2015
    Smyrna, ga
    17
    Thee multiport is a Pentair TM-22 and looks like it can be serviced by the owner from the manual.
    May 2015
    Smyrna, ga
    17
    Good Day all. After some back and forth, I finally got this Tagelus TA100d, TM-22 multiport, pump, etc from a deal on Craigslist. The MPV fit on the standpipe with a little bit of coercing, twisting prior to filling and now that the filter is filled with sand it seems a bit more difficult. Wiped up everything with a damp cloth, but wondering if anyone has methods of convincing a sticky MPV to go back on the filter/standpipe? Don't want to resort to a couple of blocks and a mallet, but not sure where else to turn.
    Thanks.
    30,432
    Quote Originally Posted by Bmholloway View Post
    Thanks.
    I am maybe lost.....are you talking about the multiport valve? Doesn't it attach with half-unions?
    May 2015
    Smyrna, ga
    17
    Talking about MPV sliding down over standpipe in sand filter, not connections to piping.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Use some silicone pool lube on the outside of the stand pipe to help it slide on easier.
    Love TFP? Become a
    TFP Supporter!
