Thread: Hayward Aquarite Issues - no power light
    No power light, gen light, or super clor light. LCD works and indicates 3100 salt level (correct) and temp. Voltage and Amps to cell read zero. Other LEDs, no flow, salt warning, etc working. Went through the trouble shooting steps, good trans, rectifiers, and have voltage to DSP board (~5v). Diagnostic book says bad board but before buying one thought I'd ask if anyone has guidance.
    Thanks
    Last edited by BoDarville; 05-24-2015 at 08:24 AM. Reason: Moved from another thread- edited references to that thread
    Re: Hayward Aquarite Issues - no power light
    Welcome to TFP!
    Try turning the percentage setting up to 100%, give it a minute or two, and see if it is still behaving the same way.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    If after Jason suggestion you still have no power, no generation and no super chlorinate, the problem is likely a bad current limiter.
    https://www.youtube.com/watch?v=7Ou-sDA0yG0
    Divin Dave,
