Thread: Aquacal Heat Pump - Split Pipe
    Last fall I winterized my Aquacal heat pump, Model 120AHDEWNB, like they suggest. I pulled both input and output pipes, and the drain plug, and let the unit drain. When I went to restart the unit yesterday, I found the pcv elbow coming out of the heat exchanger was split. It didn't seem like a big deal, but it actually appears to be glued in to the heat exchanger. Can anyone suggest a vendor for parts, and a source for part diagrams? Thanks in advance!
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Aquacal Heat Pump - Split Pipe
    Here's the manual: http://aquacal.com/webimage/pdf/aqua...ump-manual.pdf
    They have links on their page. Maybe you can contact them directly. http://www.aquacal.com/
