Results 1 to 10 of 10
Thread: Major dilemma - What would you do?
    May 2014
    Ohio
    75
    Backstory, I was getting sand in my pool. My assumption was that I had a broken lateral. I did the research and ordered 5 laterals off of ebay. When they showed up yesterday, I took the filter apart and only one of the laterals was still attached to the piping assembly. Therefore, I have six laterals and need 8. None of the local stores had them on hand. The soonest I will be able to get them is Wednesday. That means 4 days without any filtration. Here are my options.
    1. Plug 2 of the holes in the piping assembly. Put the filter back together and run. Would this put too much stress on my pump?
    2. Order the parts and run the filter on recirculate a few hours a day just to keep chlorine up. Is this ok to do with the filter being empty(I am bypassing it right?)
    What would you do?
    Thanks
    16' x 32' Hopper IG Vinyl | 19,000 Gal | Pentair Tegalus 60 Sand Filter | Pentair Challenger 3/4 hp Pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Major dilemma - What would you do?
    I would go with option #2. Bypass the filter and keep good FC levels all over the pool with the recirc. That should do you fine.
    Essential Links:
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Option 2.....
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Option 2
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Option 2
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Anyone else?
    Essential Links:
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Well, option 3 would be to leave the pump off and brush the pool every time you add chlorine. That being said I vote for option 2!
    Love TFP? Become a
    TFP Supporter!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    option 2
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    I'll go option 1 just to make it more interesting.
    May 2014
    Ohio
    75
    Quote Originally Posted by pooldv View Post
    Well, since the rest of you seem to be on the same boring page. I guess I'll go with pooldv and make it more interesting Just kidding, thanks for confirming my thoughts.
