Results 1 to 18 of 18
Thread: Bleach with SWG?
    Jun 2013
    Southeast Pennsylvania
    125
    Bleach with SWG?
    If I want to get my FC level up, can I use bleach even though I have a SWG? This year, I'm having trouble "shocking" my pool with my SWG. This pool just started its second year. Last year, I could easily raise my level by turning my SWG to 50% production and it would take maybe 4 hours. I've had my SWG at 100% the last few days and yesterday it tested FC of only 1. Last year, I did have a mineral cartridge, so maybe that helped? Anyway, can I add bleach to raise FC instead of using the SWG?
    13,500 Gallon Gunite Aggregate Finish, DE, SWG, 2.0 HP pump, 1.0 HP pump for 3 Sheer Descents
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Bleach with SWG?
    You can always augment with liquid chlorine if needed. I'm glad you abandoned the mineral packs. I think if you are slamming, I'd go all liquid until done and turn on the swg to maintain FC afterwards.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Donldson's Avatar
    NW Ohio
    2,896
    Yes, in fact it is highly encouraged to do that since it saves cell life and gives you an instant boost of FC instead of a gradual increase.
    Sounds like you might have a failing cell or more likely something consuming your FC, would you mind posting a set of test results so we can offer an opinion of which it could be?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jun 2013
    125
    Thanks Guys. I certainly hope my cell is failing....it is only a year old. Here are my latest test results:
    FC - 1
    CC - .4
    pH - 7.4
    TA - 135
    CH - 325
    CYA - 55
    Salt - 3,200
    Jun 2013
    125
    Correction on the FC and CC. I just tested. FC is at .6 and CC is at .2. This is frustrating.....I think my cell is failing and it is brand new. Maybe I should look at it and see if it needs cleaning. I have not ever cleaned it. Any advise here on that?? My manual says to dilute muriatic acid 1 part to 10 parts water and soak the cell for a period of time. Does this sound right?
    Donldson's Avatar
    NW Ohio
    2,896
    Your CYA is a bit low for an SWG, it does cause the cell to work a bit harder because more FC is destroyed by sunlight. Other than that nothing too out of line except your FC of course.
    To see if it is your cell you should perform an Overnight CL Loss Test. Shut off your SWG and bring yourself up to shock level using bleach (24 FC for you). If you pass then your cell is the problem and you can go down that path. If you fail then you have some growth and need to SLAM your pool. Remember, SLAM is a process, not just a short sharp shock.
    Jun 2013
    125
    I will perform that test, but how will that tell me anything about my cell? The test just tells me if my FC is being consumed overnight. Also, what do you suggest for a CYA level and how do you suggest I increase it?
    I just added 18 oz of bleach that is 8.25%....that should get me to FC of 1.5
    Donldson's Avatar
    NW Ohio
    2,896
    The inability of your SWG to raise your FC is either because something is consuming it just as fast as it is generating it, or because it is not working correctly. You want to rule out the former before you start working on the latter.
    Recommended Levels
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    With a SWG you want your CYA to be 70-75.
    I would wait to raise it just yet and perform the OLCT first. If you lose more than 1ppm overnight you should SLAM.
    What you need to do right now is add enough bleach to target a level of 24 as Donaldson said.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    1.5? why are you going only for 1.5?
    Do you know the FC level you need to keep your Pool clean is dependenent on the CYA level?
    http://www.troublefreepool.com/conte...art-slam-shock.
    Quote Originally Posted by dubele View Post
    Divin Dave,
    Jun 2013
    125
    Are you guys saying I need my FC level at 24?? Isn't 3 times the shock level?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    You said CYA was 55 correct? If so then SLAM level is 24
    Here is a link to the chart.
    http://www.troublefreepool.com/content/128-chlorine-cya-chart-slam-shock You fall in between CYA. At 24 this will help keep it at or above SLAM levels
    Lisa
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Yes, I often use bleach to augment my chlorine level. Much easier and more precise. Sounds to me like you have algae consuming your chlorine.
    Here is the Water Balance for a SWCG pool.
    This Chlorine CYA Chart is the key to how to chlorinate your pool. Never let the FC level drop below the minimum for your CYA level or algae will start to grow.
    I recommend SLAMing Your Pool
    Jun 2013
    125
    Just so I'm clear, it looks like I need about 450 oz of 8.5% bleach to get my FC to 24. Does this sound about right?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    If that is what pool math calculator says then yes. Make sure all you numbers are plugged in and you have the correct gallons in the the box
    Lisa
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    I had the same problem with my pool a week ago. Turned out it was algae and not the SWCG. The first indication of a problem was that I had to keep cranking up the SWCG and the FC never recovered to recommended levels. Algae was confirmed by the OCLT. I caught it early and the pool remained nice and clear throughout the SLAM. I'd bet your SWCG is fine but you won't know until after the OCLT. Make sure the SWCG is off during the OCLT.
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
    DFW, TX
    24,497
    Quote Originally Posted by robdac View Post
    Nice post!
    Sep 2014
    Oviedo, FL
    59
    Same thing as robdac happened to me too; I suspected my SWCG, turned out to be algae...I'll admit that going thru the SLAM the first time was daunting...it really bugged me that I felt out of control...but all the advice here is sound. This process works.
    And when you make it out on the other side (crystal water and all!) you'll have such a deeper understanding of your pool and how to maintain it...the TFP way!
    ~Adam 12K gal free-form pool with spa, Hayward EcoStart VS pump, Hayward T-15 SWCG, Hayward C17502 filter, Hayward Heat PumpPro 140k BTU, Stonescapes minipebble. tf-100 & speedstir.
    5.5 foot retaining wall. Build completed in Feb 2015.
    East Central FL.
