Thread: Silt on bottom of pool
    Jan 2012
    New Jersey
    18
    We just had a new waterfall installed. There was a lot of rock cutting. The guys covered most of the pool when doing the work but the dust was so fine that some did get into the pool. Ive been trying to vacuum and run the polaris 280 to get most up. Ive been brushing a lot too. Anyone have any suggestions that can help me get this up? Pools all balanced.
    Looking forward to using the waterfall and pool.
    Thanks in advance
    Chris
    27,000 Gallon Inground Gunite Pool with 150 sq ft tanning ledge. Jandy ProFlo pump, Jandy 400K LXi NG heater, Aqualink PDA w/ iAqualink. Polaris 280 cleaner.
    Jun 2014
    15,059
    Re: Silt on bottom of pool
    Chris, that's a beautiful waterfall feature. Wow! When my pool was finished, there was a ton of rock dust and grout in my pool as well. All we could do is what you are currently doing ... lots of vacuuming. I have a cartridge filter, so it had to be cleaned quite often. I vacuumed manually though so that I felt I had better control of what area(s) needed attention.
    Jan 2012
    New Jersey
    18
    Texas,
    Im going to pull the cartridge filters this AM and clean them then do some more vacuuming. I bought some new ones once all this is gone.
    Thanks
    Chris
