Thread: New IG pool plumbing question
    May 2015
    Zanesvill, ohio
    2
    Question New IG pool plumbing question
    We are building an 18' x 36' IG pool with 2 skims & 3 returns plus an 8' Roman back sit-n-step with 4 spa jets. The pump is a Hayward EcoStar VS 1-1/2". We are going to split the return between the 3 returns and spa jets so we can control pressure / flow to the jets. Are we ok using 1 1/2" pipe?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: New IG pool plumbing question
    Welcome to TFP! I don't have an answers for you, but I am sure one of our other great members will. Congrats on your build.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If you end run the pipes you will be ok with 1.5 inch on the returns, I would suggest at least 2 inch on the skimmer though.
    May 2015
    Zanesvill, ohio
    2
    Thanks Isaac-1. That helps.
