Thread: Need a good solar cover roller
    Apr 2014
    Stony Brook, NY
    159
    Looking for a good roller. I cant convince wife to spend $450 for a rocky's, So whats my next best option? Looking to spend about $250. My 1st $80 reel is really a pos, and annoying me. Would appreciate some thoughts.
    14000 gallon 16x32 roman in ground vinyl, Hayward 140k heat pump, swg, de filter 1 1\2 HP v.s. pump. Built in June 2014. Tf100 test kit.
    Dec 2009
    Central Massachusetts
    2,690
    Re: Need a good solar cover roller
    Get the Rocky's, you'll never buy another one.i just saw one for $420 online. I tried 2 of the cheaper ones that fell apart. and you can anchor the rocky to the deck. One person can roll it up or unroll it.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Apr 2014
    Stony Brook, NY
    159
    I found a rocky on eBay without the aluminium pole for $65! The pole will cost $200, so I got a rocky for $265!! Hope it works nice.
    Ukie's Avatar
    May 2012
    Export, PA
    83
    Rocky's all the way!
    suzook, what part are you getting from eBay?
    Lagoon shape, 23,600 Gal, steel walls by International Swimming Pools, "ultra-seam" liner by Latham, Pentair 011018 IntelliFlo 3HP Variable Speed Pump, PentAir CCP420 filter, Heat Siphon Z575HP, PentAir IC40 SWG, 2 LED Lights (Pentair Intellibrite 5G, 110V). 4 x 1.5’’return lines, 2 x 2’’skimmer lines, 1.5’’ waterfall line. All plumbing is "TigerFlex" pipe, all lines plumbed individually. Deck: travertine glued over concrete.
    Apr 2014
    Stony Brook, NY
    159
    Quote Originally Posted by Ukie View Post
    The whole reel except the aluminum pipe.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Just ordered a Rocky's myself. Hoping it lives up to the expectations. I paid bought the $420 online and an 8 mil cover. Wanted my wife and perhaps my oldest child to be able to handle the cover if needed.
    Isolated Spa - 345 Gallons
