Results 1 to 9 of 9
Thread: My 2nd year on the TPF method
    Jul 2014
    Deptford, NJ
    27
    Last year I discovered this site and it was the best thing for my pool. I opened pool this year and it was a little green and cloudy. My numbers are
    Ph 7.6
    Ta 90
    Cal 80
    CYA 50
    FC 6.0
    I've been testing FC everyday and trying to keep it around 6.0. I usually lose about 1.0 FC/day
    It has been opened and is getting better, but I want to make sure my numbers look good
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: My 2nd year on the TPF method
    Did you SLAM when you saw the green?
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Jul 2014
    Deptford, NJ
    27
    No I didn't, as soon as I got the FC level up the green cleared up. Should I always SLAM when I see any green?
    20' round AG, 9,500 gal
    150 lb sparco sand filter
    1hp hayward pump
    Taylor k-2006 test kit
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    I'm not the expert, but I would. I would imagine in your case it would have been only a day or two.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by nuce70 View Post
    As a rule, it's best, but if you elevated the FC for a time and it was very minor, it might be fine. Sometimes, a short period of elevated FC can do the trick, sometimes not. If it comes back when you start keeping normal FC levels, then you'll know you should have done a SLAM procedure. Often in cases like this, you can do a SLAM and it will be a very short and easy one. Being your second season, you likely have a pretty good handle on things by now, so see how it goes.
    Essential Links:
    Jul 2014
    Deptford, NJ
    27
    Thanks for the advice. The water looks good today, but just not crystal clear yet. I'm hoping it just needs more time. Do the rest of my tested levels look ok?
    1hp hayward pump
    30,432
    Absolutely. Nice work.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    The levels look great
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    An overnight chlorine loss test should give you a pretty good idea whether or not any algae is left.
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
